Stratosphere Blue
- First Name
- Scott
- Joined
- Apr 30, 2026
- Threads
- 2
- Messages
- 19
- Reaction score
- 6
- Location
- South Carolina
- Car(s)
- 2025 Supra Mk V
I might have missed it, but any mention of why the previous owner got rid of it?Car is still within my return policy for another few days, so I'm debating on whether or not to keep it based on the...interesting history. It sat unsold and was moved between a few toyota dealers for about eight months. Clean autocheck and carfax report and it drives fine.
I was hoping someone could help me make sense of these errors. Car has 9,200~ miles on it, 2025 6MT. Seems a bit weird for this many errors but I'm not familiar with BMW based systems, was hoping someone could chime in and tell me if I'm making a $63,000 mistake:
Error memory showed four errors. Info memory popped up with 55 something errors found. I cleared the info memory, and 14 of those 55~ something came back immediately after when I checked again. I did clear the error memory and did a drive for a few hours and the same four returned.
My instincts at this point are saying to avoid the car. I don't see any CEL's or any warnings. Though worth mentioning the car has had two battery replacements in its 9,200 mile life. I've had a concern with the VSC kicking on really conservatively (50 mph on a curved on ramp at half throttle) but I'm not sure if thats because of the different tires on the rear, it feels like its coming from the front when VSC kicks in.
If someone has any knowledge of Bimmerlink or the BMW systems I'd appreciate a heads up on if this is a car I should return within my return policy or if this is all relatively minor. Car drives fine otherwise, but I'd rather not be stuck with potential problems once this return policy ends.
PMA
1 error
803207: Sensor technology: noise detected
Body Domain Controller
1 error
804081: Production readiness to drive: faulty
Camera-based driver assist system
1 error
800ABF: KAFAS camera: field of view temporarily disturbed
Headunit High
1 error
B7F8F6: HDCP: authentication failed
*******INFO MEMORY*******
Crash Safety Module
7 errors
010012: Diagnosis master - info - fault memory blocked
803280: PDC cannot be activated
803181: CTA active without activation
010020: Speed - signal incorrect
803180: CTA cannot be activated
803282: RVC cannot be activated
803284: Park button reports errors
Central gateway module
13 errors
100100: Contact to FZM slave lost
100104: HW Weckgrund ZGW
100108: Functional subnet deactivation due to the startability limit
100109: Ignoring the functional subnet request due to the startability limit
10010A: Unauthorized request of a functional subnet
100203: DM software error info warning
100204: Message monitoring: no system context signal
100406: FsCSM does not send a response to F60 or F70
100600: Flexray protocol startup time is too high
100601: Unexpected asynchronous state on Flexraybus
CD0601: Ethernet: CRC error
Digital Motor Electronics
3 errors
213B02: Battery status detection: battery regeneration active
24000B: Timeout data EWS
21A026: Combustion engine: abnormal key / MSA start detected
Dynamic Stability Control (DSC)
2 errors
480AD4: RDC calibration
D35D1F: D-OBD 3 - EPS - Communication error Diagnostic status message, group error
Virtual integration system
6 errors
0305A9: QDM-QEI - limited model validity
030C67: INT-SVCHDL Input buffer overflow
03066F: QDM-ODO - degradation odometry
03065D: QDM-ZFM - Statistics proportion of linear travel range
0305AA: QDM-QEI - plausibility error
000002: FLEXRAY controller ACS error
Active Sound Design
1 error
3F100D: Message (status convertible roof, 0x342): failure or signal invalid
Roof function center
3 errors
801A0E: NVM_E_INTEGRITY_FAILED
801A20: CAN_E_TIMEOUT
801A57: Anti-theft alarm system: deactivation of IRS and inclination sensor via customer
function
Instrument panel
8 errors
B7F671: Combination: information error 9
B7F670: Combi: information error 8
B7F66C: Combination: information error 4
B7F756: Combination: External Vsync error
E106E1: SOME / IP error
B7F66A: Combination: information error 2
B7F67C: Combined: CAN input buffer, data loss
B7F779: Station wagon: mileage implausible
Telematic Communication Box
1 error
610036: Flight mode due to failed network registration
Headunit High
1 error
E1C601: Ethernet: CRC error
****INFO MEMORY CODES CAME BACK IMMEDIATELY AFTER CLEARING****
Crash Safety Module
7 errors
101008: Non-resolvable ambiguous routing - SG not in the SVT target table
100102: Invalid LocalSleepReadiness message received
3 errors
2 errors
