BimmerLink - engine running or diagnostic mode?
Optimusprimerib
P
Honolulu
23 manual base
Hello, I looked in search could not find the answer. Thank you for the replies.
BimmerGuy
Michael
Cary, NC, USA
MKV Supra m/t
If you are afraid of your battery going dead in the middle of coding, then you can do it with the engine running. However, depending on the module that you are coding, the ECU restart may stop the engine from running, and as I recall it makes a horrible noise when it happens and you think you threw a piston or something. But as long as you don't take hours to do the coding and the battery is healthy, that shouldn't be necessary.
BMWAF
In orbit
A90 Supra; FN2 CTR
I don't think that's a good idea. Just get a tender and keep your coding sessions to an hour at most. Check your battery before coding too, to make sure you are all good.
