Daily driver, reliable power upgrades, help?
Extreme Power House
x-ph.com
18 BMW M4, 13 Mustang GT
Which tuning platform/tuner has the best drivability? Can’t deal with idle surging, bucking, stalling etc.
try bootmod3
Denial
Daniel
Phoenix, AZ
2021 3.0 Premium
Would recommend against a charge pipe. People blow their turbos because they forget to add gaskets to it
digicidal
Las Vegas, NV
I would say that's an installation problem - not a problem with charge pipes in general. Not following instructions precisely can cause problems with any part of any car - but that doesn't mean the parts themselves are bad.
Add a charge pipe if you need it. It doesn't add any power, but at higher boost, or if you're spraying meth or nitrous you'll need it.
Denial
Daniel
Phoenix, AZ
2021 3.0 Premium
Agreed!
Denial
Daniel
Phoenix, AZ
2021 3.0 Premium
Also correct. But also meth through the charge pipe is a good way to have issues. Last 2 cylinders become starved
Well, sorta. If you're going to have issues, it's going to be cyl 1 and cyl 6, not 5 and 6. Using meth injector for fueling can be dangerous if you're not watching your logs, but you can safely supply a little bit of additional octane across. Especially if you're paying attention to your atomization.
Most of us use meth for cooling rather than pure octane boosting anyway - which is absolutely safe to do.
Denial
Daniel
Phoenix, AZ
2021 3.0 Premium
Interesting. You learn something new every day
