Rapid Designs A90 Supra Differential Brace
Ecom
Z
Nowhere
Mk5 supra
Received my brace about an hour ago. Came with a chunk out of the finish and a dent which had to have happened after the power coating and before shipment based on paint missing and the shipment box looking fine. I'm assuming this won't cause an issue with rust (but I'm not sure what metal this is)?
rwense
rwense
Evan
Pittsburgh, PA
Hi there!
That is purely cosmetic and deemed passing due to the fact that it is non-visible when mounted and smaller than my quality standard.
Also, the brace itself is 6061-T6 Aluminum, so no it will not rust.
Thanks!
rwense
rwense
Evan
Pittsburgh, PA
Just saw this and waiting for the next group buy 😩
Shoot me your email so I can add you to the next group buy! Im thinking of kicking one off soon actually. 😁
rwense
rwense
Evan
Pittsburgh, PA
Hustling it at Sebring. Look closely and you might just see the Raps Designs logo on that sexy anodized red diff brace. 😎
Hell yeah!
rwense
rwense
Evan
Pittsburgh, PA
Alrighty everyone! I've had a few people asking for another group buy, the next one will take place between the following dates:
08/14/2026 @ 12:01 AM EST - 08/28/2026 @ 11:59 PM EST
Depending on the response, this might end up being the last group buy for a while as I try to focus on some other products. As always, another post will be made when things open.
Thank you all!
Hasan
Hasan
United Arab Emirates
Too many to list
Thank you all!
Do it !!!
rwense
rwense
Evan
Pittsburgh, PA
Just a friendly reminder to change your diff fluid and take a gander at your sweet sweet diff brace if you got it :cool:
chrisriker
Connecticut
2020 RAV4, 2025 GR Supra
Can you help me understand what the "gear whine" would be from? That sounds like something I wouldn't want to hear
rwense
rwense
Evan
Pittsburgh, PA
So gear whine is essentially the noise you hear from gears meshing together. Every car has it but it is typically masked from the factory due to soft bushings and other NVH countermeasures.
In the Supra's case, gear whine isn't heard due to the incredibly soft differential bushings from the factory. These bushings are a double-edged sword in that NVH is decreased, but the propensity of the bushing to fail as well as negative effects from a performance driving standpoint is quite prominent. For example, wheel hop, a vague rear-end feeling, and a slower throttle response.
If you prefer more of a sportier driving characteristic or track your car, then NVH is less of a concern. Hence the reason people install stiffer bushings or a brace.
Tl;dr, the brace connects the diff rigidly to the subframe which transmits gear whine from the differential to the subframe and thus to the chassis and your ears. That being said, most people will barely notice it if at all.
I hope that helps!
