Resetting Service Lights - Brake Pad, Oil, & ETC. (CBS)
Cptnslo
Colton
2020 MKV 3.0 Supra
I was able to reset my brake using menu when it was around 8~9,000 miles.
Mine was telling me my pads needed to be changed and I installed a new wear sensor as well and still doesn’t show.
Deleted member 5830
Guest
Got as far as "Perform Reset?" Held the button - said "reset proceeding" or something. But then, "Reset Unsuccessful". Tried 5 times - same result. Any ideas?
Rocksandblues
Bob
which reset?
if brakes it will NOT reset with out a new wear sensor if you ran them down that far.
NoBadDays98
Donald
Phoenix
2020 toyota supra
I had the same issue, I replaced my brake sensor also and code still wont clear, is it hard code that can only be reset by toyota? I have 3 scanners and none of them will clear it and it's pretty annoying and from what it seems is that everyone knows where to go to reset it but no one's actually reset it them selves yet or??
Cptnslo
Colton
2020 MKV 3.0 Supra
I had no choice but to go to the dealer and have them reset it. I’m just confused why I didn’t even see the option even if it had T given me the option the reset it like it does with other functions.
nibble
nibble
NJ
BMW, Honda, Toyota
have you tried the method on very 1st post of this thread?
maxVsupra
Max
2021 MKV Supra 3.0 Premium (Absolute White)
Any new developments on the pesky "Reset Unsuccessful" for front brake pad service? Is a dealership reset the only solution?
Thanks!
J29DB03
As mentioned previously, OBD adapter and BimmerLink.
Axix23
GA
I’m thinking because the brain is German and not Japanese.
well the certain conditions have to be met to be able to reset a stupid light is annoying as hell… i mean come on
DavesMK2JZ
Dave
Sold 1984MK2JZ
OK so I just went through this and I’m going to spell it out clearly for anyone having the same problem.
If you are unsuccessful in clearing your brake reset using the dash and you have verified that your brake wear sensor is good i.e. you have replaced it if it wore down with your break pads. Then you must use BimmerLink not BimmerCode to reset or go to your dealer.
The brake wear sensor is like a squeak tab. The difference is it’s just a piece of plastic with a wire in it. once the plastic wears down letting the wire be broken the car knows your pads are low. Since the wire is broken you must replace the wear sensor then reset.
