Rear Pad Job - Retracting the e-brake?
mk5_ricola
Christiansburg, Virginia
2022 GR Supra 3.0 Premium - Turbulence Grey
A little confused on the procedure for the rear pad replacement.
I saw a video where the person retracted the piston by rotating it with pliers.
I've also heard you can put the e-brake in service mode on BMWs. Is this something we can do to avoid rotating the piston back manually? Or am I misunderstanding the procedure?
Hudson Valley, NY
Use something like Bimmerlink to unlock the piston so you can unwind it. Or... you can just unbolt the parking brake motor from the side of the caliper, unwind the piston then reattach the parking brake motor.
The pistons aren't like the front calipers where they just slide in/out, they turn.
Traxion
Southeast, USA
2022 Toyota Supra 3.0 Premium
I leave the E-brake off and don't use service mode and I'm rotating the piston in manually. My most recent rear brake change, I decided I wanted to see if service mode helped at all and it basically did nothing. I still needed to rotate the piston back in manually. It did not retract the pistons.
Hudson Valley, NY
I found out that while that works on my 2020 Supra, it does not on my 2023 M240i with the exact same calipers. You can only rotate them about one full turn until they lock.
mk5_ricola
mk5_ricola
Interesting, last time I did the pads, I did not use service mode, nor did I take off the e-brake motor to rotate it back in. Was hoping I could avoid that painful procedure of twisting it back in.
I guess there's 3 ways of doing it: service mode, unbolt the motor, or twist the piston
Thanks for the help!
AHP
CLT, NC
2024 3.0 Premium MT, 2019 Z06
Hudson Valley, NY
