Tires for A90 Supra (3.0 liter)
Axix23
GA
Does anybody have any tire suggestions for hooking from a dig with a stock car (335 hp). I was thinking about Nitto NT555 G2s. Any better suggestions?
I am running the nitto nt555 g2. I like them because of the wider size selections they have. What you could do like nitto says is run a nt555g2 in the front and a nt555r2 in the rear. Nitto says that’s okay. As far as the normal nt555, they are okay for everyday normal driving and sometimes some spirited driving. This car has too much tq to really stick with any street driven tires.
Babayaga Supra
mexico
MKV Supra
I've been running the nittos and its great tire for the street and stock turbo levels.
If you are upgraded tires and looking to race a Mickey thompson is the way
wyn.a90
Vy
Indiana
2020 GR Supra
What size are you running in the front for the nt555 g2?
suicidaleggroll
Colorado
Bumping this. If I run 295/265, will I need spacers on the stock rims?
A little late, but I’m running 265/35 and 295/35 RT660s on the stock rims. A 5mm spacer in the rear caused it to rub a bit on the fender liner so I run the rears with no spacer. I was able to run up to 12mm on the front without any rubbing, but it made the fronts poke out from the fender too much and didn’t match the rear. I ended up with a 5mm on the front.
So with stock tires it looked best with 12/15 front/rear. With 265/295s it looks best with 5/0 front/rear with no rubbing.
