TPMS for the Supra
ArmenLS1
Supra, Type R
Are the oem sensors not easily removable? I'm ordering some Gram Lights 57cr and swapping over stock tires.
I’m sure they are. I bought extra for my track wheels. But I wouldn’t if I was just swapping ?
THOOPRA
SLC, UT
20' C43 AMG, 18' Model S, 21' STI, 23' Supra
nibble
NJ
BMW, Honda, Toyota
THOOPRA
SLC, UT
Huffington, 'Huf' is OEM manufacturer of TPMS for GR Supra, I believe. not sure if there were any design change was made for 2022 but as for '20 & '21, I'd recommend Huffington which is original link.
Thank you nibble for the response! I'll be getting those ones then. They're the same part number as the 2023's so they should fit.
Cheers.
So to let anyone know, if anyone was interested in my previous post about having bought a set of TPMS Sensors off of Ebay for my new aftermarket wheels, they worked! All I had to do was go into the settings and manually choose "Other tires", I had to take it off the automatic selection the car was choosing. Then I just had to drive the car around for about 15 minutes for them to calibrate.
Here is the link to the Ebay TPMS sensors if anyone is looking to save about $70 on a set in the future!
https://www.ebay.com/itm/254835814706?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Thanks for the site. New link to them. Worked perfectly for my track tires:
2022 Toyota GR Supra 3.0 New TPMS Sensor Set Black Stem 433mhz 42607-WAA02 | eBay
Only difference I selected "summer tires" and drove around the track a bit. They magically read all the tire pressures. Even matched what I was checking before and after track sessions.
GreyMadder
WIlliamsburg, VA
Sorry to bring up and old thread but need some input. Put on my Volks and the set of sensors I had ordered originally were BHsens and did not tighten enough on the wheels. So the install shop didn't have the correct ones. I went to Discount Tire and got Dill 433hz sensors as marked for the Supra. Car would not pick them up when trying to relearn, went to Discount Tire they resest the sensors with their tool, the car picked them up but will not read out pressure and temp on the screen. The screen says TPMS monitoring active, no dash light and all the tires are green but no read out. I ran relearn twice and have driven the car about 150 miles. Am I doing something wrong? Its not a big deal but I'd like to have the feature. Thanks
Coqui
Ramon
Space Coast FL
‘22 Supra
Rustyscrew
15 Tundra, 21 Supra, 66 VW Bus
Just placed order for these. Wanted black stems for new set of summer wheels
You can buy just the black stems for the OEM TPMS. Just have to swap them on, 1 screw. I wanted black stems as well and went that route. Might save you some money if you don't need new sensors. Huf is the OEM valve manufacturer.
https://www.ebay.com/itm/293983616152
