B48 4 cylinder Supra will come to US?
Would you be interested in a 255hp B48 Supra for $40k-$45k?
  • Total voters
    59
Dannyvandelft
Danny
Ordered A91 edition Supra
You can have a neutral FF car with 60F/40R weight distribution, and you can have a neutral RR car with 40F/60R weight distribution. Handling balance is not fixed by weight distribution... The ancient 911s that exhibited understeer until you gave a mid-corner lift at which point they oversteered off the road behaved that way because of suspension deficiencies and not due to weight distribution.
FWIW I drove my ~55/45 BRZ and my ~45/55 Cayman back to back at a few track events this year, and I can assure you that the Cayman both understeered less at corner entry and put its (modest) power down better at corner exit while being every bit as driftable as the BRZ. Both have minor suspension mods for front camber (-3.2 BRZ, -2.9 Cayman) and slightly stiffer and lower springs
50/50 is marketing for the masses who don't know better. It's also a mark that is achievable for a mass-market FR car, so when manufacturers hit it, they like brag about it, even to the point of calling it "perfect", which it isn't... For sure 50/50 for a rwd performance car is *way* better than 55F/45R. But 45F/55R is better still. For serious power/weight rwd cars, even more rear bias is better. Primarily better for putting power down accelerating out of corners (as well as in a straight line from lower speeds), but there are other benefits including better braking due to rear tires being able to contribute a lot more.
There's a reason megaperforming rwd cars are not 50/50...
You're seriously comparing a BRZ to a Cayman....
There are soooooooo many variables there, I don't even know where to start. Chassis stiffness, quality of suspension, tire, front engine vs mid engine, overall build quality and chassis tuning. My God, you might as well compare a Chevy Volt to a Honda Civic Type R.
Anyway, back on topic, I don't think the balance between the I4 and I6 will matter much. IF there is any improvement at all, it'll be negated by the power difference.
ZDan
Dan
Pawtucket, RI
'17 BRZ PP, '11 Cayman
You see where I said "FWIW"? I put that in there for a reason...
That said they are not *nearly* as far apart as you make them out to be. 14.1 lb/hp vs. 12.1 lb/hp is the major difference. My 2900 lb. BRZ on 245s all around has a tire width/vehicle weight advantage over 3200 lb. Cayman on 225/245 tires (weights with me in them). Times were surprisingly close at Thompson (CT). Big advantage to Cayman at Watkins Glen. But anyway, only submitted that as *anectodal* which I thought I made clear...
For sure the idea that "less weight on the front" equals "understeer" and the idea that "more weight in the back" means "when the back comes around there's no catching it" are misguided at best, and so is the idea that 50/50 weight distribution is "perfect". It's just not true, and I invite you to do further independent research on the subject.
Oh yeah, in terms of lap times the I-6 car will be much faster for sure. But I'd rather start with a slower 3272 lb. 50/50 car and $10k in my pocket than start with a 3372 lb. 51.5F/49.5R (Car and Driver July 2019), and empty pockets...
2JZ-No-Sh*t
NM
My feet
i m kind of upset hearing this. this is really cheap marketing from toyota trying to ruin SUPRA brand as it already is.
Supra is always inline 6 cylinder, never 4 cylinder. DONT call inline 4 a supra. CALL THAT 86!! that is what AE 86 was known for inline 4.
Don't worry too much. After a year or two of poor sales they'll probably pull it from the US market.
