Cannot measure oil
Axix23
GA
First you need to drain all the oil out in order for you to remove the oil level sensors so oil don't spill out after that you remove the oil level sensors and replace with the new one.
And of course after you replace the new one you top it up with the oil you just remove or you can also top it up with a new oil and new filter (That's what I did).
Bringing it into the dealer it just cause too many issue and they can keep your car for a while and we all know in the BMW forums that is the issue just replace it and we call it a day much easier than go through all this claim for $165 job. And of course for some of us that have tuned the car bringing the car to the dealer for this cheap fix could cause a ECU to be re-flash back to OEM standard. Therefore I suggest any member what this issues just order a new oil level sensor and replace it yourself, it very fairly easy job took me less than 45 minutes.
Hope this helpful.
need to do a DIY for us.
dragonhunter241
dragonhunter241
Omar
2021 Supra A91
So I didn’t get a response for over 2 months- just a couple days ago I did get a response but by then I had sold the car because I was just too frustrated. BMW came back and approved an oil pump on the solenoid and the psi sensor replaced for the whole system. But I no longer have the car so hopefully this is useful information for everyone out there.
Tripjammer
Anybody still having this issue was the oil level sensor replacement or oil pressure valve replacement the main fix?
Supra 9
Jeff
Tucson, az
2021 Toyota Supra primium 3.0
After I replace the oil pressure sensor valve didn't have any more issue. This is my third oil change and still don't have any issues with the consumptions starting from the second oil change. I think the whole hype about the oil consumption, I really think ( my own opinions) the oil pressure sensors is the problem.
Tripjammer
I think your right my Supra is at the dealer right now for the recall and this issue hopefully they just replace the oil pressure sensor we will see!
jchadwell
Jerry
WV
2021 3.0 Premium
I'm skeptical. If true, then those who have to add oil frequently based on a bad sensor would eventually be so overfilled it starts coming out of the dipstick. Oh, wait...
Tripjammer
Well it’s more than that this sensor helps regulation oil pressure maybe if it’s off more oil is burned! We just don’t know. But this sensor is one of the main issues in the inability to measure oil level
Tripjammer
Alamo toyota service is slow to respond! I am still waiting hopefully their techs didn’t brick the car! ?
Tripjammer
It’s been two days they still working on it trying to figure it out! Hopefully they come back and say “We gonna replace the oil pressor sensor valve”
at least the recall went good we need more knowledgeable Supra techs
Supra 9
Jeff
Tucson, az
According to BMW dealer that is the problem and as long as you change that you be all right as I said this is my third oil change and I did not have any more oil consumption since the second oil change
Tripjammer
Hey bro I am fighting with the Dealership they are clueless
You are saying its the oil Pressure Sensor Valve right? Do you have the part number?
Is this the part number?
oil pressure valve assembly
part number 23950WAA01
https://parts.toyota.com/t/Toyota_2021_Supra/VALVE-ASSY--OIL-PRESSURE-CONTROL.html
Tripjammer
Damn I had to tell the Toyota Service advisor and the Supra Tech what the fix is...Hopefully they will order the part and fix it. Not sure how long this is gonna take. Its been 2 days so far. Hopefully this fixed the oil consumption too. I think it will
Supra 9
Jeff
Tucson, az
Supra 9
Jeff
Tucson, az
