Miles on car and which oil are they running.Even the 2020 are having low oil issues. We are all doooooooomed. Lol i
@3850 miles and another 3/4 quart low...doesn't seem right?..lol6/20 build date...
2 quarts in 3200 miles...?
Steve
Thanks for snapping. Well ours looks similar enough. Perhaps the waviness is how it is on these motors. I was looking at some other engines and they usually have straight lines.Edited my post..see above. ?
-RJM
No clue, not my car. lol Just know itās a 2020Miles on car and which oil are they running.
-RJM
Sounds like you have vertical scoring in the cylinders. Get that shit tested asap that's ridiculous@3850 miles and another 3/4 quart low...doesn't seem right?..lol
I've been at the 3/4 low mark for quite a while now. I've been watching it closely for the last few thousand miles and it almost seems like it's stabilised. I'm currently at 4,300 miles (6,900kms) I'm still on the original oil. My tailpipes do not show any residue on them. I did an easy break in. my build date is 03/20 (I have one of the early ECU's that can still be tuned) back to my point now. My car goes in on July 1st for the one year service, and I'm going to measure the old oil that comes out. Good luck fellow Supra owners with the oil consumption. I hope everybody get's sorted out.Right at 5100 miles now, checked the oil after a drive and got my second low oil notification so I added a quart. First was at 3600 miles so right around 1500 miles after the first. Original oil other than what I've added.
Iāve noticed that the oil level can fluctuate as much as 10mm in either direction depending on the level of the surface your checking.I noticed something odd over the weekend. While I was sitting at my auto-x event between rounds, I said hey, lets check the oil level. Car had been sitting for a hour but I let it run for another 10 min before measuring. Sure enough, level came back at half. Did the test 2 more times, same. Ok cool. Get home (about a 30 mile drive), before I shut the car off, I had it in my normal oil level check spot and measured again. Full. Wondering how sensitive the system is to temps? A half qt is a lot to be off for a 30-40Ā° difference in oil temps.
Hmm. Would make sense. Where i normally check the oil, its a little nose down. Where I checked it at the races, pretty flat. Didnt really think it would be that big of a difference, especially cause I think its a calculated measurement based on flow. If that is truly the case, being level wouldn't have a huge impact but I am just speculating here.Iāve noticed that the oil level can fluctuate as much as 10mm in either direction depending on the level of the surface your checking.
Iām not sure what that equals in oil volume based on the size of the pan. But I bet it can be as much as 1/3 of a quart.
-RJM
