Coding AUX audio with Bimmercode
fudog82
Ri
Supra
So I installed the Road Top version of MMI prime today's everything is working, coded aux,, BUT when I go to aux, I hear a very faint volume only on the left side, and whenever I speak I can hear the myself on the system and it reverbs like crazy, any idea what I did wrong? Did you guys hook up the mic thing when plugging in the kit? Maybe I messed with the fiber optic cables?
Branflakes123
Branflakes123
Boston
2021 A91 Refraction Blue
For the BimmerTech unit, I did not plug in a separate microphone. It utilizes the ones already in the car.
fudog82
Ri
Supra
That's my first problem then, I'll have to go back in. Also, you didn't plug an aux to USB adapter in did you? I just left the aux cording unplugged.
B54
Bas
Belgium, Europe
Supra Jarama Racetrack Edition
So is there a difference between the aliexpress mmi and bimmertech mmi?
The differences I could spot were:
- Different metal casing
- Different interface skin
- Easier warranty/issue handling
The case difference probably just depends on the original manufacturer.
My locally sourced MMi (but equally Aliexpress MMi) dealer told the devices might run hot. So putting the MMi behind the dashboard radio module should be safe, as there is enough space to dissipate the heat. Other people placed it in their glovecompartment in their BMW's but that seemed to be not providing enough cooling for the module.
I think the difference in metal casing is just a different/better way to dissipate the heat.
SupremeLeaderGD
Goldwin
Supra MKV
Thanks for your reply, makes me really think about which route I wanna go with. Something budget friendly or expensive with convenience.
Reactions: B54
Matthewstorm
Matthew
North Carolina
Man, this looks like the biggest PITA I've ever seen. Glad I switched back to iPhone.
