Flex Fuel Questions
bgneon
Brent
Louisiana
2020 Launch Edition #1027
Gents, I am wanting to run E85. It is my understanding that in order to do so, I will need to install a flex fuel kit. After the kit is installed, is the car drive-able with any mix of E85 and 93 octane or is a tune required? if a tune is required, any recommendations? Thanks
Advertisement
kurumi
Northern Virginia
You don't need a flex fuel kit per se but it will allow you to use a mix of e85 and 91/93 pump gas in conjunction with flash tune that accounts for ethanol fuel.
TL;DR: You need a flash tune to run anything above e25. It is recommend you get a flex fuel kit.
Bflood
Columbus OH
3.0 Premium
If your goal is e85 then you will need to add port injection. You cannot run e85 on these cars for any period of time as it will burn up the stock fuel pump however you can safely run e50 without adding a secondary fuel source.. You don't have to run a flex kit if you know exactly what's in your tank but a flash is mandatory.
bgneon
Brent
Louisiana
  • Thread starter
  • Thread Starter
  • #4
Thanks any recommend flash?
kurumi
Northern Virginia
[email protected]
Marshall
Bailey, North Carolina
2017 Nissan GTR - 2018 Honda Civic Type R
Alindoraan
David
North America
2020 Supra GR
Id be happy to help. Feel free to reach out with any questions you may have!
Just switched from MHD to flex fuel EcuTek tune a week or so ago, tuned by John Visconti. Marshall and John both are amazing to work with. You cant go wrong here. Marshall is super responsive and always answers my dumb questions. The car is running like a beast, I couldn't be happier! No issues with post-purchase support, @[email protected] is a mad man!
[email protected]
Marshall
Thank you sir!
Twisted Tuning
www.twistedtuning.com
Supra MKV, BMW 135i, BMW 335xi, Mazda 6 Twin Turbo,
As stated above, if you want auto adjusting flex fuel functionality. Right now Ecutek tune and a CANBUS ready Flexfuel kit. There are only two kits on the market for this. Mine and Viscontis as far as i have seen.
You can have tunes setup for certain mixes without the full flex functionality. But it looks like from your post you want full function. So Ecutek and a custom map for flex.
bgneon
Brent
Louisiana
  • Thread starter
  • Thread Starter
  • #11
appreciate the help! Thanks for your time. Will be reaching out
APanoMKV
San Francisco
2020 Supra LE
Any developments on how to run flex fuel using direct injection without going ported? Replacing the fuel pump for a larger one is fine or even adding a secondary one is ok too but really don’t want to drill/add injectors into a brand new car like this one.
Bflood
Columbus OH
3.0 Premium
You don't have to drill anything. Just add this spacer and whatever size injector you want. Done!
https://www.eospeed.com/products/b58-port-injection-kit
APanoMKV
San Francisco
2020 Supra LE
[email protected]
Marshall
No kidding. Wow might have to look into that then.
Edit: just saw a vid on it, it looks cool although I’d rather not have 12 injectors.
Let me know if you have any questions regarding port injection. We just released a superior kit to market 2 months ago. Most people that even already had the EOS kit ditched it and purcahsed ours.
You can run up to ~E50 on stock fuel system. Higher ethanol than that will need port injection to run to full potential
Advertisement
Advertisement
