Have a look at the Prototype Supra's engine
mrarm
Franck
france
To be fair, they have stopped making M versions of the Z4 so we all knew it wasnt going to have an S58. So even if Toyota was allowed to put the S58 in the supra, it still wouldnt be in the Z4 because BMW doesn't have a market for a Z4 M
Yes it's on a convertible with a series m it's no longer interesting.
Good frankly the M8 resembles strangely on the supra and with a V8 better than supra for US market...
SS09ER
Europe
RS13
We know we're not talking about the supra GR but the supra GRMN for S58.
Z4 engines
B58B30M1 EU present to G05 X5 xDrive40i/sDrive40i
B58B30O1 US
It just removes the Catalytic Filter
I believe the grmn will have the same engine,maybe with more power but the car will focus on low weight and suspension
justbake
Indy
F10 535i
Specs of the new 3 series have been released with having 382hp and 369 lb-ft of torque so it is identical to the Z4 engine.
With that being said, 0-60 on the M340i is 4.2s. I do not have a weight for the M340i but I do have one of the 330i (4cyl) at 3,582lbs.
Souce - CNET
Source2 - Jalopnik
3.99s 0-60 is definitely possible for MK5 assuming it sheds 300-400lbs and has the same motor as the Z4 and M340i.
A70TTR
Japan/EU/USA
They crammed a ton of nonsense into the car IMO, so I'm interested to see what it does in production format.
CantEven_Supra
Arizona
2016 Cayman GT4
Do you know if this nonsense you speak of was present on the prototype test vehicles in Spain?
A70TTR
Japan/EU/USA
Yep, those cars are damn close to what will be delivered next year and they have to test everything to ensure it all works, so they have been that way for a while. They have added a few things and changed some things as expected, but otherwise it's been in it's near final form for some time.
tha7osavage
The Bay
2015 Subaru WRX
Souce - CNET
Source2 - Jalopnik
Wow 0-60 at 4.2 is impressive for the new 3 series.
BRX
Abdulla
United Arab Emirates
Tundra, Celica, GT86
Not sure if anyone mentioned this but seeing BMW use that engine (B58) in multiple vehicles makes me believe it would be possible in the far future to "upgrade" (Engine swap) to an M engine like an S58 or even a V8 with minor modification. At least it would be easier and might reuse parts compared to a 2JZ swap or something similar that would require extensive work.
tha7osavage
The Bay
2015 Subaru WRX
Strange that the Z4 does 0-60 in 4.4, but the M340i hits it in 4.2? From what we have speculated so far, the Z4 should be lighter too. What am I missing here?
BRX
Abdulla
AWD? If that's true the Z4/Supra should do sub 4 seconds with better tires.
BRX
Abdulla
Ohhh, I wasn’t aware it’s AWD.
I believe it’s been confirmed that the Z4 hits 0-60 in 4.4.
I'm not sure the M340i is AWD, the articles I found aren't clear about that, however the 330i definitely is.
