Ohlins Road and Track Coilovers + Vorshlag Camber Plates
hfeng
Henry
Bay Area, California
2020 GR Supra 3.0
Hi, I have a set of vorshlag camber plates and rear shock mounts along with ohlins r&t for my supra, its at the shop waiting to install. one of my friends recently put this same setup on with his g80 and ran into a weird ride height issue where the front sits much higher than the rear. this prompted me to check this forum where i found that this seems to be an issue on the supra as well due to the increased stack height of the camber plate. right now i am kind of in between just selling my camber plates and running stock top mounts or just biting the bullet and getting swift springs + helpers. if i go the swift spring route can i just do the front? the rear is divorced so it shouldnt have the issue with the stack height. Any help would be greatly appreciated!
barry_ps3
Barry
Philadelphia, PA
2023 A91-MT
Also following this. I have both these parts and didnt know there would be a fitment issue. Quick google search said to ignore Ohlin's front suspension recommendations and to unload the springs in the front to reach the ideal 70mm drop on all 4 corners.
