Putting a non-running car into neutral
kaj
Fresno, CA
'00 360 / '69 Charger
To put the car in neutral, just hop in, place your foot on the brake pedal and press the start button. Engine will start. After than, shift the car into neutral.
Yep! I'm sitting here, cranking the engine, but I just can't get it running. So, I'll keep trying until it starts so I can put it on neutral.
Rustyscrew
15 Tundra, 21 Supra, 66 VW Bus
I've had this issue before. Even while its just turning over, follow the instructions on the first post and it will go into Neutral for 15 minutes.
kaj
Fresno, CA
Our remotes have an arrow button?
smr.111
Alabama
2021 Supra
Little off the topic and maybe everyone knows this, but to winch the car into a trailer in neutral you can start the car, keep foot on the brake and shift to neutral. Then stop the engine. Car will stay in neutral for 15 min or till you hit park to take it out of neutral. No need to disable the engine to keep it from starting. Apologize if this has been covered before, but I just recently discovered it by accident.
Rustyscrew
Sorry my mistake. These are the instructions I followed to get the car in Neutral when the car wouldn't start.
Hold start button and brake
Push shifter into neutral
Let shifter reset
Push into neutral
Let shifter reset
Hold shifter in neutral for 5 seconds.
15 minutes
kaj
Fresno, CA
Before you also get flame, I will answer: the title of this thread is in regards to cars that are not running.
Let shifter reset
Push into neutral
Let shifter reset
15 minutes
Yep. That's the one I'm going with, should my car fail to start. Fingers crossed as I (thankfully) have no way to test LOL
