ColonelAdama
- First Name
- Adam
- Joined
- Jan 30, 2023
- Threads
- 2
- Messages
- 688
- Reaction score
- 824
- Location
- Greenville, SC
- Car(s)
- 2023 Absolute Zero Supra 3.0 Premium MT, 2015 GTI
- Thread starter
- #1
I've seen repeatedly on these forums that everyone has their Map 6 settings dialed in by Jesse for ~$500 or so. I found this rather unusual just coming from a MK7 GTI that I've been running Map 6 for 7+ years (never had an issue, even at 26+ psi stock turbo e30). I was able to dial it in myself after doing my research on the forums, and I can't really see the reason why the Supra would be any different. (educate me if it is) I guess GTI forum users are more willing to share their Map 6 settings/supporting mods. (No, its not tune-theft. The JB4 was designed to be user-tuned, I think it's wild that we try to gatekeep the performance of fellow enthusiasts)
Setting up Map 6 isn't rocket science, and it's no doubt a cake-walk compared to proper tuning.
My method on the GTI was:
FYI: forum users trying to scare others from doing their own map 6 are just trying to make money off you. Educate yourself on how the system works and make changes incrementally!!! Your engine or turbo will not blow immediately when you raise boost by 0.5 psi. DME failsafes are in place. Your car will go into limp mode if anything exceeds safety limits (AFR, timing pull, overboost, etc).
I encourage anyone who has a JB4 to reply with your datalogs (+map settings, supporting mods). Datazap is typically used in the GTI forums and works well for sharing.
- Determine the boost curve from a base map (ie. Map 1 or Map 2). Usually 4-5psi across the board with some tapering on both ends. This can be done by datalogging on those maps and looking at "boost target"
- Bump up from the whole Map1/2 curve in small increments (ie. 0.5 psi or so) at a time
- Data log a 3rd/4th gear pull after every change (~2.5k rpm to redline). Watch for timing corrections in any of the cylinders. If any corrections observed, dial back down the boost around that RPM and log again. Do this in hot weather if possible to create a worst case scenario for IATs. If its winter, start data-logging again as weather starts to warm up and observe for IATs and timing corrections. Data-logging every season is ideal.
- If you don't really care about a linear power band, you can usually bump up the boost more in the RPM ranges where the turbo is in peak efficiency (GTI was 3-5k rpm)
- Watch fueling trims when bumping up the boost in higher RPMs (5k+) and go easier on the boost. On GTI, fuel trims need to remain under ~40. Not sure on Supra.
- Boost curve below turbo efficiency range (<2.5k rpm) shouldn't be raised much at all over Map 1/2. You shouldn't be going WOT under 2.5k anyway. Lugging is bad for timing corrections and your clutch.
- Adding ethanol required FOL adjustments but not sure how that works on Supra.
- Re-evaluate your settings with the addition of any supporting mod.
