Supra 2.0: R R8TED Build - E30 Protune (DaBears and JB4)
morfhious3
hal
evo x, isf,explorer eco boost
what you mean BT option?
morfhious3
hal
thanks again.what do you think of +22 offset ?of course with spacers.im planning to buy 18x9 + 32
18x10 + 36. and the spacer is 10mm on front and 15mm on back.
R_R8TED
R_R8TED
Dan
South Carolina
www.pixelatedgamer.com
2021 Supra MKV 3.0, 2020 Jeep Wrangler Unlimited
I'd check with your wheel source for that to be sure. For offset, I'm 25mm(Front) and 35mm(Rear) on my 19" Gram Lights with a 40 profile and love the fitment. No rubbing with those specs, that's what I would check on first and foremost. Post up with what you go with!
morfhious3
hal
thanks again . looking at wedsport RN-05M.just 18 so that i could still use my factory tires.
morfhious3
hal
are we able to stretch our factory tires or is it a good idea?im planning to do a square set up and make 18x10 all the way around.and by the way whats your offset?
morfhious3
hal
Did you install flex fuel on your e30 set up?
R_R8TED
R_R8TED
Dan
South Carolina
I wish that option was available, but with an Ethanol Analyzer kit installed and the simple fuel calculators to help, it's really simple to run E30! Just note "miles to empty" and number of fuels bars left. I always took a picture at the pump, so I had a reference of where I was at fuel wise before mixing. That will give you get a real clear picture of how much E85 to add first, before topping off with 93 ;)
R_R8TED
R_R8TED
Dan
South Carolina
You can to an extent on any ride, but I'd again check with the pros on fitment. If you enjoy pushing this car hard, I would probably advise against running a stretched setup, as that can heighten the risk of something going wrong. My 2 cents at least :thumbsup:
Donjazz
Donovan
Youngsville Louisiana
2021 Supra B48
Here you go! This is for just the JB4 (make sure you add the BT option, as that's how you monitor, datalog, edit data and switch maps on the fly, all from the JB4 app),
After you get this, you can speak with Jesse about your goals and then purchase one of his Pro tunes for the MKV ?
https://1fastsupra.com/products/jb4-tuner-for-2020-toyota-supra-mk5?_pos=1&_sid=99db0bd23&_ss=r
Your 0-60 numbers are legit....wow! Where did you get the ethanol analyzer kit from? Also, was that the only other part you needed for the e30 outside of the JB4 and Protune from Jessie?
