Anyone using JB4?
LVCATZ
Ameer
King George, VA
Supra MKV A90, S4 B8
Burbles are different than flap control.
No JB4 does not control burbles
But, you can flash in back end maps that have all sorts of more power and burbles
I have a 2021 w JB4. Run map 2 until I have time to install dp and the EWG Then I was going to dyno
guessing I’m at 420-430 now and after dp, EWG and a map with a little corn I can be at 450.
See how I like it before ripping out and going flex fuel kit and a ecutek tune from one the pros
I'm thinking about getting the EWG, decent price, but don't know much about it. Also, thinking of getting the WMI kit as well with the dual injectors. You do this yet or thinking about it? Know anyone who has? Just emailed Terry asking about it. Which map to run. Usually running Map 3.
What wheel/tire setup are you running? Especially in the rears? I think that will be the next change that is needed.
Rocksandblues
Bob
You Def want the EWG as the Ecu programmed to limit overboost
I have not done water meth. I go to track day once a month or so and the current horsepower is already well beyond my current tires and skill level. I need to spend money on tires, brakes, suspension then maybe a little HP in that order. My times would drop rapidly if I could hold in a couple corners and launch with out spin coming out of a couple others.
there is a great forum that terry and others readily answer questions and the b58 has its own section.
2Cool
Ian
Pittsburgh, PA
2021 GR Supra Premium 3.0
Running a JB4 on my '21, on program 2. Loving it so far, feels like stock but with more tire spin. No changes to daily driveability, just more overall power. Just ordered the EWG connector, looking forward to seeing how 3 or 4 feels.
65sohc
Ken
Fresno, CA
California smog is 6 years.
VA90
NoVA
2021 Supra 3.0 Premium
Is yours a post-7/20 car? Also curious about whether you have dynoed your car?
2Cool
Ian
Pittsburgh, PA
Nope, mine is an early '21, manufactured 03/20. So I could do another tune if I wanted, just going quick and easy with least concern about annual inspections here in PA.
Jesse DaBears
Jesse
Illinois
It’s fine and reliable. Had one for 3 years on an n54.
Installed a cheap used jb4 on my 2021 when I thought my Ecu could not be unlocked.
Long term plan will be a custom tune at some point
to your questions:
It’s easy, safe and reliable. Yes the obd2 cord is necessary for gauges and logging. I don’t know why you wouldn’t add? Took me 5 mins to run the cord.
I am running map 2 and 93 octane until I have time to I stall my dp. Then map3 and beyond w flex fuel and or custom tune. Drives normal until you get into it.
also the obd connection allows some other little tweaks little exhaust flap control.
Where did you find a cheap used one? Should I be looking at other cars forums?
Powaup
Clyde
youtube.com
2021 3.0 Supra
Are there any dyno charts of 2021 cars with JB4 I want to know what gains are like
Benjilis
Ben
St. Louis
Supra MKV, VW CC R-Line
What gas are you using on map 3?
I currently run map 2 on 93 octane
ran map 3 on 1 tank on e30 and fuck... was that noticeable
HookemNC
North Carolina
21 Supra 3.0 premium
I'm considering ordering a Fuel-it flex sensor so I can run e30 full time. Researching it to see if it's something I want to do or not. I have e85 all over the place so it's tempting.
superd6199
Dang
Dallas
A91 Supra Edition, RC-F, CT200h F-Sport, GS350 F-Sport, Integra Type R
Does this work with the 2021 Supras?
yes it works pretty good on my 21. I’m running it with Bluetooth and EWG Maps 3 or 4 on a E20 mix.
superd6199
Dang
Dallas
As soon as they’re able to crack the later 21 models, this place will be flooded with JB4.
My kit will for sure be posted for sale. ?
superd6199
Dang
Dallas
Boostlogic and Visconti just came out with a pretty sweet port injection kit you should look into.
