Audio upgrade options
tadda
Tom
Arizona
I really like their clean installation I agree with you that using the factory woofers would be preferable as a true woofer and added unit as a subwoofer but I suspect that would have required significant modification to the cabinet as you have described. Also added more cost as additional amplification would be necessary.
I am using the Mobridge unit for 5 channels, the high output to the woofers and the subwoofer output to the removable subwoofer. I remove the subwoofer when going to the track.
Aside from adding crossovers, the only modification which would have been needed would be to add 2 exhaust ports to the narrow rear panel of OE woofers as I outlined in my thread I posted awhile ago ...
OEM Audio never took this into consideration while developing thier system assuming the 2 rear OE woofers were not very good...
Had they done so I think they would approached things a bit differently....
ronncat
Ron
Porsche Carrera S, Porsche Macan GTS
Well.... If I do decide to go this route, I could always convert the woofer holes into storage bins. Seems a shame after doing Tadda's mods though.;)
strohw
MI
2020 X3M, 2009 987.2, 2021 Supra
I really don‘t think it’s a bad price. If you we’re to buy a decent 7-8 channel amp with full DSP capabilities your easily looking at $1500+
Your price would be a very high end high powered amp with a large sub channel. You can get small form factor 7-8 channel amps with DSP that do around 400-500w for $300-600 no problem. They're claiming 6w per channel on theirs vs 40-60w on aftermarket units but their amp is very small.
It would be interesting to see the actual tuning. They do not separately tune every speaker which is what it typically done with active crossovers and external DSP. They would be tuning the individual channels which would be 5 channels, possibly 7 if they still use the factory woofers and their separate subwoofer. They can equalize the output of the speaker channels and time align for better "imaging / staging". I personally would agree with Metal.
The most you can process is per channel and since this is hooking up to an OEM harness that means the OE system is combing multiple speakers per channel. That's not a big deal though as you could easily just run DSP on the whole system with no individual channel work and make an improvement. OE systems nowadays use center channels to get each seat a pseudo center image which makes a big mess. If they even have 1 channel to LF, 1 to RF and 1 to center then you have more than you need to make big corrections.
The 2 OE subs are deleted / bypassed in the OEM Audio + application which is a big disappointment to me...
I would have rather kept them in the system adding crossovers with some DSP applied to have them operate as mid-bass speakers...
Personally, I would never want midbass speakers behind me. That's going to create terrible imaging and tonality problems. You'll be able to localize them very easily. Plus you'd really need to make the modifications to the enclosure you mentioned and I doubt they wanted to have customers cutting holes. It seems like this product was setup to be as drop in friendly as possible.
tadda
Tom
Arizona
That's not really an issue as far as I'm concerned here....The low / mid-bass and sub bass frequencies really don't have a significant impact on imaging as do the midrange and higher frequencies do...Also having both lower the mid-bass and subs separated out will produce higher system efficiency with less distortion rather than a system simply relying on one sub to doing all the heavy lifting from 20hz to 1000hz as the OEM Audio sub does...
But yes, there would be added cost to providing a narrow rear panel with ports already installed...They could have provided the customer with the OE narrow rear panel and 2 ports already installed costing them less than $75 dollars...
Like I said earlier, I think had they evaluated the system after doing the port mod (or just simply removing that narrow rear panel) they may have approached this a bit differently....
That said, I'm very eager to hear some feedback from those folks that do decide to install the OEM Audio+ system...Particularly from those that had already done the OE sub system mod for comparison....
METAL
K2
Peoria, AZ
www.instagram.com
The factory speakers are not bad, it the terrible amp and EQ. Oemaudioplus addresses this with their amp/dsp which has been specifically tuned for our cars along with the integrated subwoofer. Anyone can throw a higher power amp and aftermarket speakers in, but tuning a DSP specific to our cars is where OEMAudio plus invested the time and money. I really don‘t think it’s a bad price. If you we’re to buy a decent 7-8 channel amp with full DSP capabilities your easily looking at $1500+
Throw in the interrelated sub and all OEM harnesses, so no splicing, and then a professional tuner to dial everything in and your over $2500.
Its all about the DSP amp, and tunING. And then having the right equipment and knowledge to dial it in.
Yes you make a valid point but a drop in 9ch Mobridge amp/dsp is $1000. For another $300 you can buy a 300w rms 8" enclosed sub.
My build for example, the labor for the amp/dsp is $700 with a planned tuning time of 4 hours. $50 to drop in an enclosed subwoofer of choice and another $150 in shop materials.
$2200 installed at a high end shop.
This results in an OPEN tunable platform with triple the power the OEM audio plus system has.
strohw
MI
Sure they do but most people just don't care. They simply accept that the sub bass and mid bass is coming from beside them or behind them instead of in front of them. Then, the more they turn their system up the easier it is to localize.
I agree with this and as well as the simple fact that you don't have any options in this car outside of custom fabrication because of where they placed them. It is what is and you just roll with it. Do we know that they completely by passed the stock woofers though? I don't recall seeing anything about them in the literature.
The only selling point of this system at the price point they're charging is the DSP corrections they've made. So realistically, if it's done correctly there should be a significant change. We're talking about fixing an enclosure for woofers vs custom EQ, TA and phase adjustment for a whole system. I could walk out and spend less then a hour with a car that cost $15k brand new, measure and make changes then run those changes through a convoluter into a MP3. I guarantee anyone here listening to before and after would say there is a massive difference. But I'm making some assumptions as to how much work they put into tuning the system that may not even be there.
tadda
Tom
Arizona
Yes...the subs are completely bypassed as they mention on their website and in my phone discussions directly with them...
https://oemaudioplus.com/toyota/supra/
*Factory subs are disconnected. After extensive evaluation, our acoustic engineers ultimately determined that omitting the use of the factory subwoofers rendered the best results to the overall listening experience. Even with attempts to re-tune, filter, and/or treating the housing, we found the factory placement (even with upgraded drivers) to be more of a distraction than a contribution to an accurate sound stage, and a misappropriation of resources.
Answers in red above...
METAL
K2
Peoria, AZ
www.instagram.com
Yes, when I spoke with them on the phone they confirmed they are not utilizing the oem subs due the poor enclosure design.
tadda
Tom
Arizona
Wow... Is your new system over 1935 Watts?? The OEM Audio claims 645W...
What audio shop are you using? I live in the Tucson area....
Reactions: zrk
strohw
MI
I think I missed them stating they bypassed the woofers with it being in between those groups of images. What's up with their wattage rating on their amp though. They claim 645w...which for the size..OK maybe but then they say 6w below it and they're using a 100w sub. I'm assuming the 6w is a miss print. I'd expect at least 40w@2ohm from an amp that size for the regular channels.
METAL
K2
Peoria, AZ
www.instagram.com
Maybe lets see:
Ch2 Front L Tweeter 175w (100w rms @4 ohms)
Ch3 Front L 4" Woofer 175w (100w rms @4 ohms)
Ch4 Front R Tweeter 175w (100w rms @4 ohms)
Ch5 Front R 4" Woofer 175w (100w rms @4 ohms)
Ch8 Rear Left component 175w (100w rms @4 ohms)
Ch9 Rear Right component 175w (100w rms @4 ohms)
Ch1 Subwoofers 1000w (500w rms @2 ohms)
So that's 2050w or 1100w rms.
Ch6 not being used but has 300w or 200w rms @4 ohm
Ch7 not being used but has 300w or 200w rms @4 ohm
I'm using Handcrafted Auto and Marine in Chandler.
Edit: link to the amp: https://mobridge.us/product/mobridge-most25-amp/
RMS info was DM'ed to me by a Mobridge rep.
tadda
Tom
Arizona
yeah, I caught that too...It's a typo...should be 645W , not 6....Ha!
tadda
Tom
Arizona
Maybe lets see:
Ch1 Front L Tweeter 175w (100w rms @4 ohms)
Ch2 Front L 4" Woofer 175w (100w rms @4 ohms)
Ch3 Front R Tweeter 175w (100w rms @4 ohms)
Ch4 Front R 4" Woofer 175w (100w rms @4 ohms)
Ch5 Rear Left component 175w (100w rms @4 ohms)
Ch6 Rear Right component 175w (100w rms @4 ohms)
Ch9 Subwoofers 1000w (500w rms @2 ohms)
Ch8 not being used but has 300w or 200w rms @4 ohm
OIC now...thanks for clarifying that...
1100 W rms max... Oem Audio+ is 645 W rms@2ohm
METAL
K2
Peoria, AZ
www.instagram.com
I never asked what the rms with a 2ohm load for the first 6 channels would be but ch6 and ch7 can be run at 2 ohm at 280 rms.
So at minimum this is a 1660w rms amp. Very powerful.
tadda
Tom
Arizona
I never asked what the rms with a 2ohm load for the first 6 channels would be but ch7 and ch8 can be run at 2 ohm at 280 rms.
thanks for clarifying.... I was just curious as you had said 3x the power ...That would be way more than enough...ha!
