Dead Battery
Meep
New Jersey
21 Supra
Has anyone ever switched batteries for the car? My battery is 100% dead, tried jumping from front and back didn’t work. I put a battery tender on 12v but trunk light keeps flashing on and off. I also read that only the dealer can replace the battery because of an ecu programming? Wanted to see if anyone had experience switching it if it’s just the same pop out and pop in a new one
Meep
Meep
New Jersey
21 Supra
Putting this out there in case anyone else runs into the issue of a completely dead battery. Tow provider came and ended up jumping the car by connecting a big jumper to the back of the car where the actual battery is and a smaller jumper on the front location. Only when both are attached the car started. I still ended up towing it to the dealership because I'd rather warranty the battery.
puzzled
Calvin
When you get the car back, can you check voltage reading from your front terminal? Is it even connected on your car to the battery..
Meep
Meep
New Jersey
21 Supra
Its connected, I hooked up a car battery to the front and electronics turned on, just wasnt enough to jump
Z4UPRA
2021 Supra 3.0 Premium
How long have you had your car? Did the battery just die out of nowhere?
I just started charging mine for the second time yesterday since it was reading 12.34 while not running. The first time I charged it was end of April 2021.
I wonder if I have to keep doing this every 6 months.
Meep
Meep
New Jersey
21 Supra
Had my car since beginning of July this year. I was checking for exhaust leaks because I installed a downpipe so I turned on and off the car 4 times and left the door open around 15 minutes? battery was completely dead.
Itengineer
MN
2021 Supra 3.0
Do you have anything permanently connected to the OBD port? That device might be drawing current
ToyoBMW
Jonathan
What the dealer is going to do is charge that battery back up and give it back to you
obito
Into the lighter or hard wired?
I wanna know too because I’m being lazy and haven’t hardwired mine with battery packs. Though if it’s just the lighter it should be safe right?
B54
Bas
Belgium, Europe
Supra Jarama Racetrack Edition
Nah only thing I had was a dash cam plugged in the 12volt
I remember this being permanently providing power. So always sucking power even when the vehicle is turned off. So you need to hardwire it to a power source that provides a few more minutes of energy before the car is turned off.
See my thread or others theirs about dashcams for more info:
https://www.supramkv.com/threads/wiring-dashcam-via-fuse-box-but-no-power.9880/
I'm confusing things. My bad. 12v "cigarette" lighter should be fine. As long as it stops providing power after around 6mins :p
Meep
Meep
New Jersey
21 Supra
I put it in the lighter, I also had a battery pack for the dash cam, Dealership replaced the battery for free tho because it was covered under warranty.
They put a new one in for sure because the new battery has a toyota sticker not a bmw one. Mightve been a defect, they said the battery was completely gone.
ToyoBMW
Jonathan
Very nice, I'm surprised Toyota would brand a battery like this. Only 1 car uses it, the Supra. If they aren't used often enough, they would sit and go bad at the warehouse.
