Non-budget audio system - Morel integration reference + Morel integration performance underseat woofers + mObridge K2 amp + JL audio sub
Teleguy11
Jerry
Oldsmar, Florida
You guys are killing it with car systems these days. BRAVO!!!
In my day, I had an MB Quart component system in my '95 Maxima with subs that at that time was the bomb.
The digital systems of today are over my head tech.
Keep up the great work and remember, its the 1st watt that counts. ????
Nehpets808
2021 3.0 Turbulence Gray
Can't wait to get this lil fella hooked up. Last part of my audio upgrade. Have Morel hybrids all around with an Audison 8.14 amp/DSP on them. This 12" will get 1200W from an Audison AF M1D.
shurbaji17
Jordan
Dyer
Supra
Hello, I need desperate help so i’m stuck on subwoofer setup. My issue is that the OEM Amplifier fuse in the rear fuse box keeps popping. I have no clue why, I believe it is F217 and is a 40a. It was working fine before I tried adding a sub and now every time I attempt to put a 40a it pops immediately. I disconnected my aftermarket sub and amp and it still pops every time i attempt to put it in. Even though it worked perfectly fine before . I am stuck have no clue what to do. Any help is appreciated thank you!
tracer bullet
Greg
MN
2025 BMW Z4 M40 6spd
Powered sub, or not powered? If not powered, it's possible that it's causing the amp to pull too much power, and that blows the fuse?
If powered, it might be more likely that somehow the sub is not grounded properly, and it's using the signal cable from the amp as a ground, and that's what's doing it.
shurbaji17
Jordan
Dyer
Supra
Not powdered sub, I have a CT Sound Hydro 12” Dual 4 ohm 1000 watts Subwoofer
And a Skar 1200 Watt amp
I disconnected my aftermarket sub and amplifier and my fuse in the rear box still pops immediately, even when no connections are connected and just regular oem subs and speakers.
Sam B
Sam
Northeast PA
2021 Supra
Make sure you do a lot of sound proofing. Resonix is the place to use. That SI will get down
