Project Corvette Killer
drift72032
Brad
Arkansas
Supra
So my dad is floating about his brand new corvette. I need to find a way to put it in my rear view mirror. Here is what I have done so far….
1. New AWS Touring Exhaust
2. JB4 Install map 1
3. Function Werks 3.5 downpipe
4. Injen Cold Air Evolution Intake
5. CWS Heat Exhanger.
Need suggestions on how to destroy it on a highway or street (doesn’t matter). What else can I do other than meth? Keep in mind I don’t want to blow up the engine. New turbo system is doable.
drift72032
Brad
Arkansas
Supra
Any of the bigger turbo kits reliable and ok for the engine?
dzeleski
Dylan
LI, NY
2022 Supra, 2017 Tacoma
You are gonna need tires and >450 at the wheels. My dad has a C8 z51, it puts down like 440-460 whp and weighs 3500.
Supra weighs 3350, so its a bit lighter. I walk away at 480-500 wheel. Catted DP + exhaust, E50, RT660 @ 295, Ecutek, and 50/50 water/meth. Stock turbo.
You can see stock vs stock here:
Edit: If he plans on getting a z06 you are gonna need a turbo
wheeliedub
Eli
Arizona
Go pure 850 and call it a day. Speaking from experience but anything more than that and you’re on borrowed time. It may not blow immediately but you’re gonna be deep into it and batting well outside of trying to beat a corvette.
drift72032
Brad
Arkansas
Supra
So does the kit come with everything I need or would you suggest I get some better parts outside of the kit?
I'll ask again, because it's important. Are you unlocked?
wheeliedub
Eli
Arizona
@zrk Brought up a good question… if you have a 21 or later that isn’t a unicorn (unlocked from factory) you will need start by getting your ECU unlocked. This is pretty costly in itself. Honestly depending on what you have done, I would say with driver mod, down pipe, tires, and some balls you should beat a corvette pretty easily.
