Quickjack BL5000EXT Extended Length - Will it fit???
consultadrone
Southern California
I have an opportunity to buy a Quickjack BL5000EXT at a stupid low price. It's the previous model equivalent to the current 5000TLX extended length setup. Basically, it's 6" longer. I've looked at the guides...done the measurements...and it's right on the edge of the fitment guides of being too big to fit the small wheelbase of the Supra. Only way to know is to test fit...which is a bit of a pain as it's not close and I doubt I can get the setup into the Supra. So I figured I throw it out there to the forum in case someone has tried it.
Carbon0
ATL
2020 supra
I have the 5000tl and it fits perfectly. If you were to extend it by 3 inches on each side then it might fit but best case scenario it will be hard to get it down in there.
consultadrone
consultadrone
Southern California
Yeah, that's what I'm figuring. Sucks to turn down such a good deal, but oh well. Thanks!
nibble
NJ
BMW, Honda, Toyota
I think it will be at border line.. if you get it, make sure tires are not touching any side of QJ before taking wheels off. if you take wheels off when tire is squeezed, it will be almost impossible to put the wheels back on. only way might be bleeding air out of tire, mount it, lower it and then put air back in. But in some occasions, that is not even possible. just watch out when you lift car and make sure only touch point is jack point of the car.
Gabe
Gabriel
Miami
I don’t think they will fit based on QJ fitting guide. I have the 5000TL and it just fits perfectly. Very little room left.
