Speed Engineering | Cold Air Intake Duct - Group Buy
AZ Zupra
Dev
phoenix AZ
2020 GR Supra, 2009 GX470
Thanks! I guess when I clicked translate the page to English the buy option was gone. Did you ever get any definitive temp numbers? I was partially motivated to check out this intake because of your build thread.
I'll have data once the season starts. Unfortunately, I won't have temp at the filter data from before.
AJRMKV
2023 Manual Supra
I misspoke the hole would only go thru the radiator shroud where they put it in the install video. It faces down into the high pressure zone and would not be visible. A hole alone would create continuity with the area behind the light and may be able to be placed without removing the bumper. I plan to investigate.
Did you ever investigate?
Did you end up running this?
No sensor yet. I did find out that the duct does in fact bring fresh air in, but I found that out in a round about way. The first event of the season here, they did not clean the track, so us in the advanced group were basically driving through crap for the first session. My airbox was full of dirt and sand after.
Eyelise
Jeff
NorthEast
2005 Lotus Elise, 2023 Supra
I have not got around to opening up the bumper shroud but based on what we are hearing here it should work. I would likely put a frog skin over the opening to minimize the dirt collecting in the space behind the bumper.
SavagePassenger
Michael
Just got one of these - that's good to know lol. That's one thing I didn't consider with having a fresh air tube. Guess I'll just make sure to keep up with cleaning my intake filter
AJRMKV
2023 Manual Supra
How long did it take from order to delivery?
SavagePassenger
Michael
It was surprisingly fast. Ordered it last month on the 12th which was a saturday ,and it got to me the next Friday with DHL. Now I'm just trying to find the time to get it installed.
Erty
Eddie
Los Angeles, CA
'24 Supra 3.0 Premium MT
Installed this last month, it wasn't too bad. Although, afterwards I found out I could've replace my horn at the same time while everything was off the car already :/
