Spool and Dorch HPFP upgrades
If some people don’t understand the increased complexity of an additional fuel rail, connections, six more injectors, and a electrical box controller with all sorts of wiring compared to a simple bolt on HPFP I just don’t know what to say. It's like 10 failure points versus 1.
Not everyone is a drag racer shooting for a billion horsepower. In fact, it’s a very very very small percentage.
black_sedan
black_sedan
BR
Northeast Florida
a90 Supra, Ford Raptor
Full e85 capability on stock turbo seems like its feasible with just the HPFP. I agree that PI is the better value if you want to make more power and room to grow, but you're still spending $2k for PI + Reflex vs $2k for the upgraded HPFP.
Im not wanting to upgrade the trans anyways, so at $2k for a plug and play pump that will allow me to run e85 on stock turbo would work for me
PI is more than $2k for sure. Don't have a manifold? Then you need to buy a port injection plate and an aftermarket charge pipe.
Port injection plate: $900
Charge pipe: $270
Reflex PnP kit: $1,500
ID injectors: $800
$3,740
+ labor
+ someone to tune reflex for you
+ Ecutek
+ ECU and cloning for 2021+
^ that last bit is another couple thousand bucks alone.
black_sedan
black_sedan
BR
Northeast Florida
Charge pipe: $270
ID injectors: $800
$3,740
+ labor
Ive seen the plates + injectors around $1400 plus reflex at $700. I completely forgot about the harness and charge pipe. Thanks!
Don't forget that Ecutek is the only current offering to support CAN inputs from reflex so if you are a 2021+, add a couple thousand more bucks for ecu and cloning.
_Sp1ral0ut
Jeff
SC
Probably a dumb question and I'm sure I know the answer, but decided to second guess myself. Yeah, I always overthink shit. Can MHD (without clone) handle HPFP/injectors?
I don't have personal experience here so I can't say 100% but AFAIK, all the tables you would need to modify to accommodate HPFP and injectors are in the ECU from the factory, no custom code AFAIK.
I also believe both MHD and BM3 are going to be adding end user toggles for the HPFP at least.
EddieNel
Eddie
Central Louisiana
F350
Theirs no doubt it will but theirs no way of knowing how far you can go without a good dyno run. Oh btw I absolutely hate your avatar. No offense. I just hate it and I don’t know why!lol
_Sp1ral0ut
Jeff
SC
It's okay. No offense taken. Not everyone can handle Arnold in cybernetic drag.
Charge pipe: $270
ID injectors: $800
$3,740
+ labor
+ Ecutek
Reflex can run just fine as a standalone.
That’s funny! So many times I have seen you and others say only ecutek can run it well because of the CAN integration, usually when you and others are defending Ecutek as the superior solution.
I guess if it fits the current narrative…
No, because if you look at the fine print on the website it says that "proper low pressure fueling" is critical for the operation of the HPFP. What they're saying, because they don't want to be explicit about it, is that the numbers they're claiming only apply if you upgrade the low pressure fuel system. If you do not, you're stuck at E60. The HPFP is not the bottleneck for what you want.
Same thing with PI, no?
Vimugsy011
Mugsy
Southern California
2020 Toyota Supra
I recently priced out PI and to do it properly, your looking at about 4-5K installed, not including LPFP. I don't think any of us would recommend running PI on an AIC1 controller.
The proof will be in the results, right now Spool has shown 650WHP on e50 with pump alone, 750 after adding Injectors, and probably going to see over 800 with cams. Most mechanically inclined car people will be able to install these fairly easily, 20 min to install the pump?
