Stock top speed without vmax?
B54
Bas
Belgium, Europe
Supra Jarama Racetrack Edition
I've been looking around but can't seem to get a good answer for this.
The limiter is set to 250kmh (155mph) for a stock engine.
Just out of curiosity, does anyone know what a fully stock motor is capable of in the Supra without the speed limiter?
Also what happens if you hit higher speeds? Would the engine just blow up eventually if you keep pushing the pedal without the vmax limiter?
Bimmercode has the option to disable vmax and since I live near the German autobahn I had some "what if's" :p
jchadwell
Jerry
WV
2021 3.0 Premium
Don't do it. Body panels started separating at 156 MPH on the pre-production test cars.
BG500
Thomas
Norway
2019 Supra
The engine will not blow up, sooner or later you will hit the rev limiter and that will limit your top speed. I'm not sure what the revs are at 250 in eight gear (didn't get to try it while in Germany this summer) but if bmw has done their job correctly, and they usually do, the then the revs should be somewhat close to limit at 250
AustinGRSupra
Austin, TX
2020 GR Supra
Iā€™ve taken mine to 160. (Speedometer, so actual was a bit less). At that time I had a wing, coil overs, front and rear power braces, front and rear sways, and it started getting floaty and unstable.
I personally wouldnā€™t push it above 160 without a front lip and a rear diffuser in addition. And then Iā€™d still be wary.
Reactions: B54
suicidaleggroll
Colorado
This isn't correct at all. Gear ratios are constant, which means if it was at 7k RPM at 250 kph in 8th then it would be at 2.8k RPM at 100 kph, which is very far off (that might be the ratio for 6th, definitely not 8th). The Supra is almost certainly drag-limited above 250 kph (I'm not sure at what speed though) rather than gear-limited.
Reactions: B54
NitroYellowMKV
Phillip
South Florida
2023 Burnout A91 MT
IDK abt stock but a buddy of mine in his 340 with stage 2 e40 did 192 on video, so gearing was not an issue, 179 for me, but stage 2 as well, but I would doubt this is a 175-180mph car at least stock with enough space, stock I ran into the limiter plenty of times and it def had more in it, stock limiter in u.s is 163 for all the supra's even tho it says 155.
I thought this was a sarcastic post..
Your engine will not blow up. :rolleyes:
romanLegion9574
FWIW, the stock tires are rated to 186mph, if I'm not mistaken.
I might check out the transmission tuning in Forza Horizon 5 to see what the math there suggests. Stock tuning usually feels fairly close to the real car. I think Forza Horizon 4 suggested the BMW Z4 could do about 183 without a limiter, but I don't remember the ratios there.
Reactions: B54
BG500
Thomas
Norway
2019 Supra
My point was that speed has nothing to do with the engine blowing up, but you are probably right about the drag coming into effect before the rev limit
Reactions: B54
Sereph102889
Wes
Guyton
I can say with certainty that I hit 150mph once on my stock tune and the car had room to go, a decent bit of room actually. Now with my stage 2 tune, the car seems to hit 150 like it used to hit 120 lol.
Sereph102889
Wes
Guyton
Highest I've gone is right at 160 on my stage 2 tune. My car doesn't have any aftermarket aero but it felt very planted to me.
romanLegion9574
Also, I've got 160 in 6th near redline with no functional aero. Arrow straight, well maintained roads are the key here. It feels like there's about 20-25 mph more left to give.
Reactions: B54
B54
B54
Bas
Belgium, Europe
Thanks all for the (insightful) responses, but I see mostly stuff about engines with tune and/or stock engines with limiter enabled.
Has no one disabled the limiter and did a max speed run on a fully stock engine? ?
I do understand it is hard to do safely and legally, but I was hoping some information was available on it...
