supra_hopeful
Upstate NY
2022 Toyota Supra 3.0 Premium, 2006 Infiniti M35x
yep, try 2 gal E85 in the tank if you wanna run map 2
Alright, I have two new logs now with 2 gal E85. Timing looks like it cleaned up a lot, still getting a bit of throttle closure ~3200 rpm. I'm also seeing 4-5 psi lower boost readings vs some of the other posters' recent logs. Is that a catted vs catless difference, or do you think there could be something else there? Another member also mentioned that.
Map 1:
https://datazap.me/u/th3nemyace/map-1-2-gal-e85?log=0&data=1-2-3-4-5-8-9-15-20
Map 2:
https://datazap.me/u/th3nemyace/map-2-2-gal-e85?log=0&data=1-2-3-4-5-8-9-15-20
ColonelAdama
ColonelAdama
Greenville, SC
Map 1:
Map 2:
Map 2 looks good, you can run it.
boost changes based on IATs(and a to a lesser extent some other factors like DA) so no point in really comparing to anyone else
ColonelAdama
ColonelAdama
Greenville, SC
Beamerboy
Austin
Tampa Florida
2021 Toyota Supra
V24 or newer firmware, use the duty bias settings provided in the first post of this thread with FF at 35
Okay sorry I forgot to mention I’m automatic idk if that matters but yeah. So set the firmware to beta? And then I’m confused on how to change ff
mustafazumit
Mustafa
Indiana
2021 3.0 supra
No it does not matter on your jb4 app go to settings and click on advanced. you should see the section for frimware and click that. you should be able to browse frimware and look up b58/48. it has to be the 158 one. then download the stable version of the frimware then flash it (should take about 3 mins)
Beamerboy
Austin
Tampa Florida
2021 Toyota Supra
Dang Looks like previous owner was on b58 gen 1 firmware. How do I change the duty bias ?
mustafazumit
Mustafa
Indiana
2021 3.0 supra
in the same section as settings you should see "user adjustments" you will have your duty bias in there. since he adama asked you to set ff at 35 it should be in the options tab once you click user adjustment. Just make sure that you save any changes that you make, you will know if it was successful if the car does 2 signal light clicks
Beamerboy
Austin
Tampa Florida
2021 Toyota Supra
Okay I just made all the changes to duty bias and ff. Map 2 and took a log. Still seems to be cutting throttle as around 4500 rpm. https://datazap.me/u/austin101400/log-1746834174?log=0&data=1-4
harutora
Harutora
Vancouver
2024 MT GR Supra 3.0 Premium (Absolute Zero)
I'm going to be honest I have NO idea what I'm looking at, did a 3rd gear pull from 2500rpm to 5ish/6ishk rpm. I have no idea what to change or do. this was Map 2, was getting some pretty bad throttle hesitation, so I switched to map1 and it's been smooth. but I want to get more power out of it. please advise
2024 MT, Catless Downpipe(Kenji Garage), RKTi titanium track edition, CTS intake
datalog on datazap
ColonelAdama
ColonelAdama
Greenville, SC
datalog on datazap
try with FF at 10
duty_15duty_20duty_25duty_30duty_35duty_40duty_45duty_50duty_55duty_60duty_65duty_70
606020202020202030404040
supra_hopeful
Upstate NY
Thanks for all the help so far. I got to do some logging on Map 4 yesterday, still on the same tank of ~E20. After the first two pulls, I changed the duty bias settings to the aftermarket dp settings in your first post that I had initially overlooked. Throttle seemed mostly good after the change except for one ugly pull, not sure what happened there. Anything to look out for here?
https://datazap.me/u/th3nemyace/map-4-e20?log=0&data=1-5-9-10-11-14-17-18-25-26-27-28-29
jmikes
Jake
Tampa Bay, Florida
2021 3.0 Premium Silver
Would anyone be able to check over this log and let me know how it looks?
Only relevant mod is an MST V2 Intake and xHP Stage 2 transmission tune. Stock DP, stock exhaust.
Map 6 by Jesse (Did it 8 months ago, so I think it's too late to go back to him for revisions?)
https://datazap.me/u/jmikes99/jmikes99?log=0&data=1-4 (Last quarter or so is with JB4 disabled. 85 degrees ambient and high humidity, and at sea level.)
Dragy pics from a couple weeks ago (same settings, but ~15 degrees cooler out at the time. I did not have xHP at the time though.)
Thanks!
ColonelAdama
ColonelAdama
Greenville, SC
Looks pretty good, keep an eye on trims. I'd probably IAT spoof around 100 to keep them more consistent
ColonelAdama
ColonelAdama
Greenville, SC
Thanks!
Looks fine to me. I personally prefer an additive map like this on E20
map6_15map6_20map6_25map6_30map6_35map6_40map6_45map6_50map6_55map6_60map6_65map6_70
1​
1.5​
2​
2.5​
3.5​
4​
4.5​
5​
5.5​
5.5​
5​
4​
