blazzzed1
john
MD
2025 gr supra
Got_M
Kyle
KCMO
2022 Supra 3.0 Premium
Got_M
Kyle
KCMO
Hey all, throwing my hat in the mix here. 2022 AT, Catted DP and Intake. Took a Map 1 log to start out and would appreciate anyone taking a look at it before I move on to Map 2, thanks.
https://datazap.me/u/th3nemyace/jb4-map-1-log?log=0&data=1-2-3-4-5-8-9-15-20
Need to do a 4th gear only pull from 2500-6500. Looks like traction kicked in a bit, otherwise good. @ColonelAdama Boost levels between this run and the other map 1 recently are way off. Different jb4 versions maybe?
supra_hopeful
Upstate NY
2022 Toyota Supra 3.0 Premium, 2006 Infiniti M35x
Thanks for looking. This was a third gear run, latest B58 gen 2 stable firmware, one click traction mode. I didn't feel or see it kick in.
blazzzed1
john
MD
2025 gr supra
Boost and timing look great. What is map 1 targeting?
Im not sure what you mean by targeting beside most hp while not running too rich/lean. I'm trying to see if i can try map 2. I've read all the info on 1st page and still lost... might as well be a different language to me
ColonelAdama
ColonelAdama
Greenville, SC
Hey ColonelAdama, I’m new here. I’d appreciate if you could take a look at my log. The log has a pull from 2nd to 3rd. Then another pull starting from 3rd.
From what I see, everything looks ok. There is some slight throttle closures but I can’t say I can feel them to be honest. Drivability seems similar to stock. TC was on (forgot to turn it off before I started the log).
https://datazap.me/u/supma/log-1745874439?log=0&data=&solo=15-19&mark=63-60-66
GR Supra Manual
- Kenji 200 cell DP
- 92 Octane
- JB4 MAP 1
Looks pretty good but try with FF at 40 next, throttle cutting in too much
ColonelAdama
ColonelAdama
Greenville, SC
ColonelAdama
ColonelAdama
Greenville, SC
ColonelAdama
ColonelAdama
Greenville, SC
supra_hopeful
Upstate NY
ColonelAdama
ColonelAdama
Greenville, SC
Bug2th
Rich
Folsom, Ca
A91-CF AZ, 1998 GSX
Wondering what you use to truncate data in the log files. I tried opening in ss. Looked for the timestamps to delete rows and resaved as a csv file but when I opened it back up in the jb4 log viewer there was a lot of empty space and some of the data options were not smooth anymore. Is there some meta data that the app uses that needs to be updated (just thought if that so I need to check)?
