XHP Reviews and Feedback!
A91rookie
Jose
2021supra
I definitely need to adjust the blips. I have a built pure stg 1 and maaaaaannnnnnn this shit is rough on certain down shifts. Would like to know who here is running a stg1 pure and what are your settings on this xhp?
Maki2282
Spain
Toyota supra a90 3.0
Can someone help me with the configuration of the launch control? what settings did you have?
Uwatm8
Kyle
Acura RDX, CLS63 AMG
Same. Stage 1 down shifts are terrible
ReiH
Pennsylvania
2023 MKV Supra Premium
I’m running stage 3 with some minor tweaks and it’s made driving the car more enjoyable for me. I drive a lot in M mode so the manual blip adjustments to throttle, and the overall increase in shift speed are very worth the money I spent.
I’ve also practically disabled first gear.
When driving in M mode and the 1st gear is essentially disabled, does your car go into 1st gear while in this mode? I have it so it permanently locks 2nd gear but when I shift to manual mode, it goes down to 1st and I have to upshift twice (1st->2nd then 2nd->3rd) for an actual gear change.
32bitsofGil
Gilbert
Taylor, TX
2021 Supra 3.0
Yes in M mode when coming to a stop it will still shift into first. I started driving more in D mode to mitigate this
ReiH
Pennsylvania
Thanks for the quick response. I just installed xhp stage 3 so messing around with settings here and there and found out about the 1st gear situation.
I heard that with updates to stage 3, they fixed the shift from 3->2 so I guess I don't have to adjust that in the throttle blip setting. Do you use the shiftmap editor at all? So far I have the 2nd gear setting, and max rpm.
underdonk
'21 Supra 3.0 Premium
Which update was supposed to fix the downshifts?
underdonk
1.1 of stage 3 supposedly. Vincent's YouTube video also stated this
This wasn't just released within the past month or so, right? This is the update that came out a bit back.
stormgreysupra
stormgreysupra
Budapest, Hungary
www.oemplusdesigns.com
GR Supra A90 Edition
Yes it came out after like 1 week of the initial release
underdonk
Alright cool, thank you that's what I thought. Stage 3 v1.1 does not "fix" the 3 -> 2 downshift harshness. It maybe made it a little better but it's still very present. I've been running this since release with the downshifts set to varying levels of aggressiveness. But I'm also just a guy on the Internet.
@ReiH
ReiH
Pennsylvania
@ReiH
Would you say setting it to -15% would be good for the 3->2
Xproplayer
Aaron
Bay Area, California
2021 Supra White
I can't speak to stage 3, but I'd try 5% increments for adjusting the throttle blips or tq reduction upshifts, if 3-2 is very harsh right now 10-15% could be a good starting ground.
XHP is very easy to iterate on. I set a value 5% different, flash (<3mins), take a test drive, pull into a random parking lot, repeat.
