I've zero track days on mine... but after reading a few too many oil consumption posts and comments elsewhere I figured I should check mine since I'm close to my next change (~6.5K miles since last change) and oil is right at the top line still. I'd definitely expect more loss under heavy track use... but that much in two days still seems abnormal.Oh wow i'm surprised. I checked my oil when i got home and mine seemed fine. Even though you did one extra track day than me i cant imagine it would have made that much of a difference but i could be wrong.
Grabbed this from another thread. Don't know if that will help, but I've seen a few other people on here complaining about the 21my burning through oil. BMW faced a class action lawsuit because of oil consumption issues a few years ago. ?āI check mine today it showed at the mid point between min and max with 1,535 miles. I found other past post showing this
link.https://www.bimmerworld.com/BMW-Engine-Oil/
BMW Oil Consumption
BMW engines are designed to consume some oil and there are factory-authorized guidelines for how much is considered normal. In order for the oil to reach critical areas it's normal for some of it to make it's way into the combustion chamber and be burned up with the air/fuel mixture. If your BMW engine is consuming/burning oil, do not panic. It could be normal operation. Side note: Leaks and consumption are not the same thing. Oil leaks may also be a "normal" fact of BMW life but they should still be properly repaired or diagnosed. Below is a table outlining accepted oil consumption for BMW engines (data is from BMW).
BMW Engine Code Normal Oil Consumption B-series turbo engines (B46, B58) 1 liter per 1,500 miles N-series 4/6-cylinder turbo engines (N20, N55, etc) 1 liter per 1,500 miles N-series non-turbo engines (N52, N62, etc) 1 liter per 1,500 miles N-series V8/V12 turbo engines (N63, N74, etc) 1 liter per 750 miles M-series non-turbo engines (M54, M52, etc) 1 liter per 750 miles S-series Motorsport engines (S54, S55, S65, etc) 2.5 liters per 1,000 miles
Engine Break-in. Oil consumption will be higher in the initial life of an engine. This is known as the break-in period. All of the moving parts have not yet seated in their final positions and gaps and clearances may be greater than normal. The break-in period varies by engine but BMW advises not to be concerned with oil consumption in the first 10,000 miles. Break-in times may be less depending on use and care.
that chart doesn't seem right. that's excessive. If so, poorly designed motors by BMW.........Grabbed this from another thread. Don't know if that will help, but I've seen a few other people on here complaining about the 21my burning through oil. BMW faced a class action lawsuit because of oil consumption issues a few years ago. ?ā
Right? Those are close to rotary engine oil burning figures....that chart doesn't see right. that's excessive. If so, poorly designed motors by BMW.........
Difference is rotaries are designed to burn it lol!Right? Those are close to rotary engine oil burning figures....
I donāt know if this is accurate, but on the FB group Iām a part of it seems to be people who have followed their break in procedure by the book. Supposedly the people who ābeatā on their car and drive them like they are meant to are having less issues.Just a point of data collection, I'd be curious to know what people's break-in procedures were for those burning oil out of spec? Not implying causation or that there's even a correlation, but it'd be interesting to look at that with respect to the consumption rate.
Yup. You don't "beat" on it, but you allow the car to fully warm up, let's say 10 minutes or so of careful driving, low loads, short shifting, etc. Then on an on-ramp you give it full throttle through a few gears. Let's say 2nd, 3rd, and 4th. Then on the interstate itself you cruise, going through all the gears, just letting everything cool down for a few miles. Then maybe another 3rd or 4th gear pull before you get off an exit and using manual downshifts, do lots of engine braking. Then get back on the interstate the other way, and do the same thing. Then cruise gently back home, let everything cool and settle down before you park it and shut it off. Do that a few times and everything is nicely seated and broken in. I've done this method with every new car I've owned and I've never had an issue with any engine. Inline 4 turbo, inline 6 turbo, boxer 4 turbo, rotaries, V6, all have been perfect from buying to selling.I donāt know if this is accurate, but on the FB group Iām a part of it seems to be people who have followed their break in procedure by the book. Supposedly the people who ābeatā on their car and drive them like they are meant to are having less issues.
I have no idea if itās true or if those people are full of crap, but itās interesting none the less. Im no mechanic by any means so I donāt know if being more aggressive makes everything actually seat properly or not.
