Gears Not Engaging 2023 6MT - Really need some help here
kaj
Fresno, CA
'00 360 / '69 Charger
If it was clutch release bearing, would it just fry the clutch completely having been driven for 2k miles?
If the clutch weren't engaging fully, then yes. But you seem to be having the opposite issue. Your problem would be extra wear on the synchros.
CWO5805
Jimmy
Northern Virginia
2024 Mikan Blast MT
Crazy question. Do you have a BMS clutch stop installed?
Perfectelu
Spiro
Ny
2023 Toyota Supra 6MT
Not sure if this adds to diagnosis but turned the car on today, gears go in smoothly while parked. Very hesitant to drive the car though obviously.
Thinking of driving to the end of the block and seeing if it happens again. Live on a dead end so I’m somewhat comfortable testing a little. Any thoughts?
Eastwood
Maybe ask a buddy to come over to help you push, just in case.
BMWAF
In orbit
A90 Supra; FN2 CTR
Just ruling things out. Again, I'd be rolling back into the super duper workshop and asking them to take a look. Since it was the last modification done, it makes sense to start there. No matter how unlikely you think it is, the chances of poor workmanship/part quality are never zero.
I’ve only seen problematic clutches on all the “research” I’ve done on this thing.
Not all research leads to your conclusions.
kaj
Fresno, CA
Agreed with taking it back to this shop, since this is obviously an install-related problem. But it's still fun to do the detective work, in the mean time.
Perfectelu
Spiro
Ny
lol did you say “super duper”? You must be a troll. People like you are the reason why people say the car community sucks.
I never said it was unlikely the shop made a mistake. That’s why it’s being brought back there this Friday.
Change your condescending tone bud, horrible representation of this community.
Perfectelu
Spiro
Ny
If it was install related… how would you (or anyone else willing to add their 2 cents) deal with that? Never dealt with such a situation before. Let’s say if the clutch is truly fried.
BMWAF
In orbit
A90 Supra; FN2 CTR
You must be new here. Best of luck with it.
tracer bullet
Greg
MN
2025 BMW Z4 M40 6spd
I feel like I wouldn't drive it, I think you're finding good info on what it does or doesn't do to help diagnose it, but it hasn't fixed itself.
Does it kind of act how it would act if you didn't push in the clutch pedal at all? Say you started the car (on a normal day), and tried to put it in gear without stepping on the clutch pedal. Basically it'd resist (to a point, I guess you could force it).
If it kind of acts that way I wonder next if it's something equivalent to the pedal not getting pushed in? I know you do push in the pedal, but maybe the next couple of actions that would normally happen, aren't happening. Slave cylinder dead, or massive amounts of air in the line, something like that.
Perfectelu
Spiro
Ny
Exactly that. It acts as if the clutch isn’t being pressed at all. Fully locked out of all gears when on.
Car has been sitting since Friday and now when turned on it goes into all gears but I’m assuming if I drive it around the problem will return.
Brake and clutch do feel normal though. No sinking, no unusual softness. Feels fine as far as I can tell.
kaj
Fresno, CA
I would do exactly what we are all telling you to do: take it back to the shop that installed it. Something obviously isn't right and the are obligated to help.
Exactly that. It acts as if the clutch isn’t being pressed at all. Fully locked out of all gears when on..
That's what we've all been saying this whole time. It's acting like the clutch is not disengaging all the way. You need to take it to the installer and have them figure out why.
The more you drive it, the less chance of saving the clutch and higher the possibly of ruining something in the transmission.
We recommending you get it to the shop as soon as possible to get it fixed. That way, you can enjoy driving it again.
Is this the first clutch you've had installed?
Perfectelu
Spiro
Ny
Car has been sitting since Friday and now when turned out it goes into all gears but I’m assuming if I drive it around the problem will return.
Car hasn’t been driven since. It’ll be dropped off on Friday via tow. Yes, first time getting a clutch installed. Never needed to have one installed before. First failed stock clutch.
Reactions: kaj
kaj
Fresno, CA
I think you mentioned the original clutch dying after only a few miles. I'm wondering if there isn't an issue with the car itself.
