Trestoningle
Treston
South Florida
Toyota Corolla
I really should update the Pi section on the thread. I'll quote this. Also just to make sure is my wording wrong?
So my question is, does a femto unlock car have the ability to be controlled through the reflex for port injection using BM3 Now with customrom?
D3ad_Hand
D3ad_Hand
UAE
Hopefully soon enough with the Rev2 board, but as it stands now no.
D3ad_Hand
D3ad_Hand
UAE
So with custom rom BM3 there is no advantage for a ecutek tune?
Sorry but your question does not make sense. If you have a Supra with an ECU pre dating June of 2020 you can go for ecutek if thats what you want or custom rom BM3. If its you ECU is after June of 2020 then you need a Femto unlock and then you can tune on BM3. You can not tune on ecutek on any Supra after June of 2020 unless you find a donner ECU pre dating June of 2020 and send it to femto for cloning.
Dannyepidemik
Salt Lake City, UT
GR Supra 3.0 Premium
Sorry, I am wondering if there is any advantage between the two regardless of locked ECU and $$$. Before custom rom BM3 it is clear ecutek has more tuning capabilities with port injection. Hopefully this makes sense?
D3ad_Hand
D3ad_Hand
UAE
Yes it does if your car is a 2020 port injection controller can be integrated through ecutek it self.
Islindur
Poland
Had:Yellow 2l Have: Red 3l
Qucik Q: can I bolt-on hybrid turbo without tune and drive it for few hundred kms without risking any dmg? Driving calmly, no full throttl etc.
I wanna send my stock one for upgrade, re-install modified one, then drive 500km for tuning in another place.
Twisted Tuning
www.twistedtuning.com
You can but recoommend getting at least a base tune. seems like you already have your tuner picked out. You should be talking to them.
Yes. I did it this last year when I put oem ROM back on for inspection. Drove it two weeks, even with some boost. Logged everything. I wouldn’t be going WOT as you will get a bunch of throttle closures and oem tune runs pretty lean AFR.
alfi.mke
Wisconsin
Dodge Challenger Scat Pack MT
This might be a dumb question but:
running bm3 right now with just OTS stage 2 93 oct tune. If I buy the bm3 flex fuel kit can I run the Stage 2 multi map? Will I make more power running e30/e50 blends?
C5 4 NOW
Jermaine
Chicago
Supra
I didn’t know this. I thought a Reflex and harness would be required to run port injection on my 2020.
That is correct. He is stating that with Ecutek, you have more integration with the DME and the Reflex box.
Also, Bootmod3 has their Rev2 box coming out VERY soon (currently out for S58) that also will have full integration with the DME. So more options.
C5 4 NOW
Jermaine
Chicago
Supra
Thanks for clearing that up for me. I have ECUtek already. Just thought I was going to save a few bucks.
