swrdply400mrelay
Having run a Pure700 (very close to the new 650) and now a Pure800... Skip the 650 and get the 800. More efficient, less bp, etc.
Just not the cast 800 unless you bore out the WG outlet before installing.
So for Pure 800 you would get the rebuilt 800? Are the reliability issues with the rebuilt overblown?
Erty
Eddie
Los Angeles, CA
'24 Supra 3.0 Premium MT
Yup. I started having issues at 29psi+ 6,000rpm on.
M550i or M5/X5M LPFP pump is a nice OEM+ upgrade.
Is the precision raceworks stage 1 (28% increase over stock) pump sufficient? I'm staying away from PI, but want to maximize a pure800, ds25, and s58 inj setup. I'll be happy with ~650whp (I say this now and will probably get bored in 2 weeks)
alfi.mke
Wisconsin
Dodge Challenger Scat Pack MT, Supra 3.0
HPFP will help with added power under the curve in low to mid range. Injectors will help with more power under the curve 6000rpm+.
I run both DS25 + S58 injectors on Pure800, with E40 and 600whp+. Enough to make trans slippy slip.
Next would be LPFP.
is there a better option for a hybrid turbo to keep as close to stock spool as possible? Looking to hit 600whp with flex fuel + DS25 + S58 combo
ColonelAdama
Greenville, SC
Pure 650, pure 800, daw ultraflow x, etc.
Pure650 but would be pushing it pretty hard.
Pure800 isn't too much worse than 650, you get used to it. I come from big turbo 4 cyls though so none of the hybrids on the B58 are really "laggy" to me.
svomadness
Brian
Denver
M240i
Does the OEM M5 fuel bucket assembly drop right in or just the pump itself? Any idea roughly how much headroom we would gain for the swap?
