ColonelAdama
ColonelAdama
Greenville, SC
ColonelAdama
ColonelAdama
Greenville, SC
Thanks for the info.
Where can I read more about this?
This is called a timing correction - any step down from a cylinder ignition advance from the linear climb to redline. (ign1-6 parameters).
just means that the car detects conditions for pre-ignition. Not necessarily knock, but it is how you know you've reached the limit of the octane. some is fine, like in yours. i would imagine going to Map 2 will make it worse.
ColonelAdama
ColonelAdama
Greenville, SC
Share the log! I'd like to take a look, even if I'm still learning what I'm looking at lol
Here's @Eastwood 's latest log. Bumpy road so you can see TC kick in a little (timing dip). Or an MT quirk that needs to be worked out... We'll see on a smoother road lol.
https://datazap.me/u/coloneladama/log-1724878009?log=0&data=1-2-4-8-11-20-25-26-27-28&solo=2-4
Perfect timing otherwise at about 18-19psi on 91/E30. Notice how low WGDC has to be on MT cars. Way too high of boost and choppy throttle if any higher.
Dven11
Daniel
2024 Supra
That is interesting, 20s for WGDC. On a manual car, do you also set FF at 40? Also, since timing is looking good, would a higher octane be beneficial to get more boost or would the throttle still be too much of an issue?
ColonelAdama
ColonelAdama
Greenville, SC
Almost every MT I've done ended with FF between 15 and 25.
Throttle is irrelevant of boost levels and timing. Its just used to control boost targeting when your WGDC tuning isn't very good. If you tune your wastegate stuff well enough, throttle will barely close if at all under full load.
Eastwood
When I get a chance, I might go for a dyno and see what the numbers are.
Cfdproductions
Dan
Albany ny
23 A91mt
Throttle closures and gets the boost down to appropriate levels.
Just making sure you are saying that it helps smooth out the boost to keep the throttle closures to a minimum or do you know what they changed to help with the throttle closures?
