I installed the pre-cat O2, post-cat O2 still uninstalled (let me know if this should change). I thought with the catless DP the O2 readings don't matter since it will throw a code regardless so I left them on my old DP since I wasn't using any O2 spacers. What really convinced me is my DP came with the little caps for the O2 ports and so I'm like ahh yeah I don't need those things plugged in anymore. :doh:
The front 02 sensor is used by the DME to properly set AFR. 100% need it.
ColonelAdama
ColonelAdama
Greenville, SC
well i guess full open loop is a way to fix the MT throttle closures
Nah now I'm actually curious though. I sent the "case study" to Terry to see what he thinks. I wonder how JB4 factors fuel trims and AFR into its operation and if it affects the boost control or this is more on the dme side.
That no O2 sensor log had no business looking as good as it did for a catless MT ?
a90Omen
Andrew
Indiana
Pushing the JB4 MT tuning to new heights with O2-less tuning? Was my plan all along :cool:
Here’s a run on V24 with your suggested settings: https://datazap.me/u/a90omen/log-1729276349?log=0&data=1-4
I only ran ~500mi without the O2 and had the JB4 gauge view up every ride watching AFR and never had anything too far off 14.7. I never noticed any rough running either so I’m curious to hear what Terry thinks.
ColonelAdama
ColonelAdama
Greenville, SC
Will need a few revs. I'll shoot you a PM later with what to try. Your AFR is measured with o2 sensor :) so the 14.7 was null. Terry thinks your car ran lean, so check the plugs if you haven't yet.
Blueg20
kevin
Tristate
supra / m340i
ColonelAdama
ColonelAdama
Greenville, SC
Frosty
IL
2024 Toyota Supra & 2023 Jeep Gladiator Mojave
Are the "issues" with JB4 on the manuals only being experienced with an aftermarket dp? I was going to install a catted AA dp but I changed my mind and decided to hold up on that. I have yet to order the JB4, if I go that route but want to minimize anything that may make add to the clean functionality on the JB4.
ColonelAdama
ColonelAdama
Greenville, SC
It just takes more effort to dial in. On a stock dp car you don't really have to touch duty bias much.
AA DP is going to be way less changes than catless for example
Frosty
IL
I was under the impression that it only happened with the addition of an aftermarket dp. So with a stock dp are there common settings to use or it's best to datalog? Thank you in advance.
Eastwood
There are no issues since @ColonelAdama worked so hard with Terry to refine the settings and launch a new firmware.
MTs just require more fine tuning and patience whether it’s catless or catted. My MT Supra has been feeling great on e30 thanks to @ColonelAdama
Everything has been good.
ColonelAdama
ColonelAdama
Greenville, SC
It is in the first post :) Stock dp just update to v24 and FF at 30 to start
Cfdproductions
Dan
Albany ny
23 A91mt
I have a jesse tune and love it but i want to push the platform as far as possible for the 6mt guys and I am working with Colonel to see what he can make the car do as well with his own tune. My guess is combined information between both tunes plus a few things i have picked up along the way is going to yield me the fastest results for the manual platform but we shall soon see.
ColonelAdama
ColonelAdama
Greenville, SC
Yessir, i have been teaching you along the way so you can continue to test on your own as well. We'll get there. Trims is definitely a big bottleneck for us right now. Pretty much capped out at +5psi additive on E20
Frosty
IL
How do you route the cable for the OBD2 port with a manual? There's a hose for the clutch slave where you would normally run it through.
