Top Mount Dyno Results
Your bottom end will identify as 'blown to hell' if you're not careful...
Good power though! Surprised by the bump of torque in the middle as well.
Not at 700. My stock block was fine for dozens and dozens of passes at ~800hp. There are a bunch of stock blocks fine at 800.
BadDecisions
Nate
Ohio
LS Swapped FRS, 3000gt VR4, 2020 Supra
Good to hear. Was under the impression (I can only assume I read it on here somewhere) that ~700 was the safe limit. Maybe I'll need to up my boost a bit on the next iteration...
travsam89
travsam89
Travis
Colorado Springs, CO
2021 Supra, 1998 Trans Am WS6
Right, which means 590whp seems more accurate. There is literally no arguing this.
Correction doesn't magically create horsepower.
Not arguing, its obvious a car at 6,000+ ft is going to make less than a car at sea level.
_Sp1ral0ut
Jeff
SC
2021 Supra, 2026 Sequoia, Nike Air Max Torch 4s and flip flops
You guys do realize you are all on the verge of destroying space/time?? You cannot post dyno results on this forum in a timely manner. There must always be a two week period between everything.
Tune - two weeks - post that you are testing - two weeks - revision - two weeks - IG post on first tune - two weeks - rave -two weeks - post that you will be on the dyno in two weeks - two weeks - schedule dyno time - two weeks - IG post on second revision - two weeks - post sad dyno results without the results - two weeks - spiritual journey into the Everglades - two weeks - rinse and repeat - two weeks.
This is the Way.
travsam89
travsam89
Travis
This is the Way.
Stop using chat gpt to post your replies…
_Sp1ral0ut
Jeff
SC
_Sp1ral0ut
Jeff
SC
