Warranty issue- vibration 2021 Supra
strohw
MI
2020 X3M, 2009 987.2, 2021 Supra
Personally, the first thing I would do is have the wheels road force balanced locally and then test again.
Jomartijr
Pantego, Texas
2021 Supra, 2015 Subaru Forester, 1994 S10 pickup
That's a really good idea and I'll ask it be done.
Okvilln
Toronto
'21 Toyota Supra | 20' Audi S5 SB | 11' R8
I feel the same vibrations from time to time. Itā€™s as if the lane assist is buggy and activating at a barely noticeable setting.
Reactions: zrk
Jomartijr
Pantego, Texas
That's the sensation I'm describing. Try it at 75 mph on the smoothest road surface you can find, see if it's most noticeable there.
If Toyota refuses to acknowledge this is a driveability issue then I'll fix it on my dime.
antonio88x
Antonio
Jupiter, FL
I have a slight vibration around 60mph. It feels like the lane keeping but I have that at minimum and I'm centered in the lane. But if I go faster, above 70mph, it goes away. I so just drive faster lol
type-964
Nowhere now here
A91 Supra
I feel this occasionally as well. It became a bit more pronounced after I installed the rear Cusco power brace (man is that stock ā€œbraceā€ a joke). Itā€™s pretty infrequent and, as said above, solved by driving faster. It seems like a perfect storm resonance kinda thing, as I feel it in the same areas of a couple roads I drive on.
Jomartijr
Pantego, Texas
Resonance is a great description. "Road steering resonance" even a better one.
alan7467
Alan
Parker, CO
2023 Supra 3.0 Premium
Out of balance tires tend to behave like this. The vibrations being noticeable at certain speeds and less or totally imperceptible at others. Focusing on the tires first is the right move IMO. Hope it gets squared away for you soon.
TimM.
Tim
Vacaville, CA
2021 Supra premium
I agree and they will be looked at 7-14. I will update you all on the outcome
Resonance at high-speed is usually a problem that is solved by ā€œRoad Force Balancingā€. I had this exact problem after purchasing a separate set of Michelinā€™s and wheels for track use. After the install, I took a test run on the hwy and around 90-100mph the car resonated where it previously rode glass-smooth. Took it back to the tire place and had them do the Road force balancing and it tested glass-smooth after.
https://www.hunter.com/find-equipment/
Jomartijr
Pantego, Texas
TimM, thank you for that information?
Jomartijr
Pantego, Texas
Update- just had an alignment and front tire dismount and rebalance ( conventional, not road force) . The original issue is 90% gone.
All this was complicated by some sloppy work- mixup of remounting wrong tire on wrong wheel front to back by powdercoating company.
So, bottom line it's much better, a trace of vibration remains but a acceptable.
Tsuekasa
Henry
Detroit
www.instagram.com
2020 Supra 3.0 Premium 2018 Wrx Sti Base
I had a similar problem. Had Toyota check my alignment, checked the shipping spacers on the front suspensions, etc. My problem was a combo of two things. I replaced my rear tires and the TPMS very sensitive and turning on traction control on turns where i wasnā€™t loosing grip. That was resolved by resetting the tire pressure and manually selecting the type of tires to ā€œotherā€ instead of summer tire. I was still having straight line stability issues so i replaced my front tires After 18k miles. Everything is good.
Jomartijr
Pantego, Texas
I think its all a tire issue and how the suspension transmits road/ tire feel.
I'm not done yet, still have road pressure tire balancing to do. Ultimately I might replace tires but that's a last resort.
