What map on JB4 is safe for me?
AHP
CLT, NC
2024 3.0 Premium MT, 2019 Z06
Map 1 or 2. Unless you're comfortable reading logs, or have someone that can, I would not blindly run Map 3 or even 4 without bumping up the octane. 20psi is asking a lot on pump 93 beyond single gear pulls.
Mk5Gio
Gio
Arizona
2022 Toyota Supra
Nobody ever mentions map 5? What about map 5 on e30 blend?
AHP
CLT, NC
Map 5 with a good E blend works well but still has its issues with throttle closures. I went 11.2 @ 124MPH on it. A custom map is always better. The key with any of OTS maps is having sufficient octane/knock suppression.
Chrishyu
Georgia
A90 Supra 2021
so would you say that map 5 is an overall good map? i just got jb4 and im starting to look into details of the maps rather than sticking to map 2. im running e35 with a catless downpipe so i would like to know if this would be a good map for me.
i3igpete
Chicago
2023 3.0L 8AT
with e35 You're probably okay from a knock standpoint, but might be maxing out fuel trims. Take a log with map 4 and 5 and upload them to datazap.
however, since you've got a catless downpipe you will likely need to adjust your duty bias table (regardless of the map you choose). we can do that as well with your logs.
