60-130 Manual
Frosty87
Nick
Masontown pa
Ttc6z06/ m240i/wrx/titan/supra
if possible, ride 4th out to 130 to try and get a better time, this is my e25 jb4 custom tune 60-130 3-4th gear. (if you’re comfortable with just about hitting redline) i’m sure you could shave off half a second if not more.
I'll try it out. Only reason I saw a post on Facebook where someone said you needed a turbo to get under 10sec 60-130. I guess I could have just came here and used the search function.
Erty
Eddie
Los Angeles, CA
'24 Supra 3.0 Premium MT
I will post my times as soon as my new clutch is installed and broken in. My 3rd and 4th are completely cooked, lasted around 5k miles on OTS MHD E40 tune
Pxtra
Pxtra
Dakota
Mk5 Supra
what clutch did you end up going?
Cfdproductions
Dan
Albany ny
23 A91mt
I’m gonna click off a 7 sec 60-130 here shortly and I’m a 6mt on stock turbo so don’t believe the google
vegasZ06
Sam
2023 Z06 , Plaid 2022 , Supra 45th Mikan Blast
I usually run 100-200kph
Stock I went 9.2 100-200kph and 10.8 60-130mph
I don’t have the slip but I went 8.4 60-130mph and 7.21 100-200kph on an e40 mix map6 Jesse tune
I unlocked and did a 7.29kph on the ots e40 tune
Working on a back end flash now and only made 1 pull so far which is a 7.18 100-200 kph
Obviously the DA is all over the place but all these pulls have the same mods armaspeed intake CTS chargepipe rk downpipe full weight
If you want to follow check out IG or TikTok @AntiAutoA91
How are you hooking in 30* weather?
ntfrendlyGR
shane
Concord Twp, OH
2024 6mt Supra GR
Here’s MHD backend. 140 IAT and timing drops to 5😡. High DA. 72% humidity. I have norstrum injectors. Fastest 100-200kph is 6.5. Just waiting on dorch dc3 and will order Visconti lpfp soon. Probably won’t install till fall though. Also probably try the FI interchiller also. All the hellcat and ZO6 guys run them here and love it.
