60-130 Manual
Pxtra
Pxtra
Dakota
Mk5 Supra
I do get a little stumble when shifting easy from 1-2. Basically only when under 1/4 throttle and shift between 2800 and 3500rpm. Definitely doesn’t bother me and the only thing I’ve noticed between revmatch and it off. I’ve noticed if l push the clutch in and say hold it in for an extra .5 second it doesn’t do it. It is weird but not a big deal. Take rev match off everything is perfect.
did you order from CES Motorsports? the total cost i think with the cnc billet dmf is 3000.
saw this https://trucranemotorsports.com/pro...kit-for-b58-bmw-toyota?variant=51656735588668 for a good amount less but not sure on the quality.
ntfrendlyGR
shane
Concord Twp, OH
2024 6mt Supra GR
I do get a little stumble when shifting easy from 1-2. Basically only when under 1/4 throttle and shift between 2800 and 3500rpm. Definitely doesn’t bother me and only thing I’ve noticed between rev match and it off. I’ve noticed it I l push the clutch in and say hold it for an extra .5 second it doesn’t do it. It is weird but not a big deal. Take rev match off everything is perfect.
Yes CES
DM, twin Sinster
Took 3 weeks I believe
Erty
Eddie
Los Angeles, CA
'24 Supra 3.0 Premium MT
Hey, does the new clutch still work properly with the revmatch? i heard some aftermarket clutches are too heavy
Yes rev matching works perfectly fine, no issues on my end. This clutch isn't heavy, actually feels like stock.
AJRMKV
2023 Manual Supra
Little more E and better brake boosting
Legendary DA! What's your tire setup and how much boost? I'm barely able to hook at 70 degrees at 60mph let alone 45 degrees
djf
2024 Supra MT
This is a flex map which I think tops out at 28lbs. Running 17” welds with a 305/45/17 MT street R on stock suspension
