How to Improve OE Sub Bass Quality and Eliminate Vibrations
Tripjammer
most people have drills I would think and a hole saw adapter is very cheap
Most people don’t have this stuff bro! I am just saying would be cool for somebody or some company to come up with a pre made subwoofer back plate with the ports already in it since just like the side wind buffering fix, this is something all Supra owners need to address.
diablo2112
Southwest USA
2022 BMW M3 Competition
Some of these recent comments are hilarious. In generations past, *any* car-person would have a garage full of tools and know how to weld, use a lathe or press, and would fabricate many parts from scratch. That was a necessary skill set and you'd be laughed out of town if you told someone you couldn't drill a hole in a part for a modification.
Tripjammer
Come on now bro what you just said does not make any sense you don’t need these skills to enjoy this car! Some of y’all taking this stuff to seriously
Tripjammer
What kind of American male doesn't own a drill and a tape measure?
Once again you don’t get it but oh well I got all the parts and I am an engineer I was speaking of other people who don’t want or don’t know how to do this! I wanted to make it easy for these folks! The Supra forum is turning into the corvette forum ?
SupraMK86
20 3.0 Premium
Sick burn. Not all forum members are male or American, but I agree that if they can afford a Supra they should also splurge on a drill and tape measure.
Well, if they aren't American then they depend on Americans. ;)
D.Flynn
Lebanon, TN
Yugo
Does anyone have any advice for installing the wadding? I followed Tadda’s instruction, but it is difficult to tell how it’s laying out. Couldn’t really tell how well the long screwdriver worked Can anyone share some tips of how they were able to tell it laid out correctly?
T.I.A.
john99teg
johnreb
bay area, california
a91 nocturnal special edition
For the wadding, I folded the outside part into the middle then put it through the top vent. Once unfold, just use the flathead screwdriver to make it go against the walls of the metal enclosure. It will take a little patience but you will get there. Also does not need to be perfect as long as wadding goes against the bottom and walls, you should be good. Took me 5 minutes each
Reppunkamui
Toyota Supra 2020, Toyota Supra 1994, BMW 135i M-Sport,
T.I.A.
It was pretty easy to be honest. Just push it through and wiggle it until it fits correctly. You can tell it isn't fitting correctly because it doesn't feel even...i.e. some parts are hard and compressed.
D.Flynn
Lebanon, TN
Yugo
I can’t see anything looking into the ports. It wasn’t hard to install, just not sure it’s in place correctly
pav911
Pav
Peterborough, UK
Range Rover, Mini JCW
Just curious how everyone else has been able to see what they were doing through the vents. I am doubtful mine is spread out very well
I don't think you need to get it perfect. I felt like I hadn't done a very good job of it, but it still made an improvement.
Tripjammer
I added the second skin layer on top of the DynaMat extreme last night! Overkill I know but wow sounds even better. Base is very punchy with no rattles! Make sure you have a roller when your applying the Second Skin! Stay away from the wires and Battery and you will be fine!
