65sohc
- First Name
- Ken
- Joined
- Mar 8, 2020
- Threads
- 11
- Messages
- 464
- Reaction score
- 272
- Location
- Fresno, CA
- Car(s)
- 65 GTO, 69 Corvette, 65 Corvette 427, 23 Corvette
Order sent. Thanks.
Order sent. Thanks.
Cool, great news. I ordered Twisted Tuning custom tune and flex fuel kit. I'm ready to move forward with the unlocking process. PM or email me with info on where to send send ECU and if there is any other directions i need to follow in the process. Thankswe can do the bench unlocks as always.
Feel free to ask any questions. I can answer anything you need or want to know. And feel free to reach out for a custom tune. MHD supports ALL models via OBD2, including the Locked ECU. We are THE only ones right now with this support for the locked ECU. No bench flash needed
Have you received your tune yet?I ordered my e50 tune Monday. It would be great to have it before the weekend.
Yes this is before the intercooler. And your boost is also before the throttle. Your turbine maps are likely not dialed in all the way as the duty cyc le creeps up on shift. It looks like the tune has the turbine power map shifted up at higher flows to try and get more boost.Is the charge air temperature read before or after the intercooler?
It does pretty decent at the boost levels in that log. But it starts getting toasty especially when you over run the stock turbo to try to squeeze more power. The manufactures did give us some room which is nice. But more could be desired when we start leaning on the cars.I get it. So the spike is what would be controlled with the blow-off valve in a typical aftermarket turbo system. Also, the IAT is extremely consistent so it looks like the intercooler is quite efficient.
do you need to have the android phone in the car always, or is it just for setting up the tune and flashing? And also can I turn off my CEL (CEL coming from my catless downpipe).?completely understand, but an android device can be had for $50 on a base model bare bones. thats what 1000s of people have done.
Only when flashing, logging, or checking codes. And yes takes care of the catless downpipe celdo you need to have the android phone in the car always, or is it just for setting up the tune and flashing? And also can I turn off my CEL (CEL coming from my catless downpipe).?
DOES. MHD ALLOWS YOU TO INCREASE THE POPS. AND BANGS ON THE SUPRA FOR THE STAGE 1. MAP?Only when flashing, logging, or checking codes. And yes takes care of the catless downpipe cel
YesDOES. MHD ALLOWS YOU TO INCREASE THE POPS. AND BANGS ON THE SUPRA FOR THE STAGE 1. MAP?
