Speedometer correction with Bimmercode?
Vertex
Vertex
Vertex
Midwest
2022 3.0 Supra
My Fords were pretty close to dead-nuts on.
All three BMW products I've ever owned were by far the worst. It's sooo bad from the factory.
Every vehicle I have driven so far all the way back to when I used GPS seems to be spot on as well. 2018 Challenger GT, 1999 Silverado, 2021 Mach 1, 2022 Mazda CX-30 and every other car in between that I borrow from work.
Wondering if it's a European car thing maybe? I know someone mentioned something about false readings being to low over seas but I also have never had a Japanese vehicle either so I'm not sure which area or if it's from both parts of that world where they are super strict about false readings if reading below your actual speed since the opposite affect can get you into trouble whereas if you're overreading and underreporting you aren't doing anything wrong.
FuzzyRev
RT
Wisconsin
It's 100% an EU thing. There's actually a law about it that I dug up once because I complained about the issue on my A91 right after I bought it.
J29DB03
So… this new law over there that requires the car to scream at you when you are going over the speed limit, it’s actually screaming while you are going under the speed limit. ?
Vertex
Vertex
Vertex
Midwest
2022 3.0 Supra
I turned off all notification stuff except I think if you are about to rear end someone it still yells at you
BMWAF
In orbit
A90 Supra; FN2 CTR
I'm pretty sure our cars down under can be within 10% of the actual speed.. as long as it's under.
Spart
2023 A91-MT
TEN percent slow?
I know it's the wrong accent but oi bruv, you got a loicense for that accurate speedo? :lol:
Stedy
Sydney
24 MKV Manual, BMW 330i M Sport Touring
Yeah, I've got an XC60 here in Aus that is calibrated about 4% out. The 10% max is correct as per ADR (Australian Design Rules).
I don't mind the speedo offset. With speed cameras here becoming so prolific and the buffer between the speed limit and a ticket being drastically reduced, it's probably saved me a more than once during normal driving.
Rob_SER
Montreal
GR86, GR Corolla, K24 BRZ, C8 Z06
the GR corolla does it as well. Noticed it on my supra this morning too... GR86 seems on point.
