Start/stop disable module....
BeepBoop321
Eric
2025 Supra 3.0 Premium
I gave up and just use Bimmercode to code the default Start in Sport Individual mode. That essentially disables the Start/Stop
Hmm. I’m not near my supra, which is why I am asking the following question — I know that I can toggle what sports mode does in the settings (transmission, handling, etc). If I change the four attributes in the regular mode to ‘sport’ and change the four attributes in sports mode to ‘normal’, am I essentially swapping both modes?
If this is the case, then I’ll also use this approach
J29DB03
There is no Normal Individual, only Sport Individual. You can code it to start in Sport, leave it in Sport at all times, and set the Sport Individual selection screen as a preset to just change whatever you want between Normal and Sport whenever you want.
Vertex
Vertex
Midwest
2022 3.0 Supra
So after I got the recall on mine for the DCM update the coding out option for the start/stop feature stopped working.
I just have mine now set to start in sport mode and left everything still in sport except transmission that I toggle depending on what I'm doing since I prefer to drive the car in sport anyways. Essentially it feels like I'm just driving around in normal mode since the transmission is still shifting at low rpms instead of holding around 3000. This is what I would recommend unless you wanted to toggle any of the other options but this was my favorite/ideal workaround
licklobster
Phoenix, AZ
23 Supra. V8 Exocet
You can remove it with an xhp trans tune permanently
BeepBoop321
Eric
Just did this. Works great, will leave it like this until someone makes a dongle to disable ASS, or until hopefully BMW re-enables the option. I do prefer the option of using a button to swap between modes.
Vertex
Vertex
Midwest
2022 3.0 Supra
I’ve just used one of the presets to bring up sport mod options to change the transmission one on the fly instead of hitting the sport button so it isn’t changing multiple settings unnecessarily.
MavJ
J
YVR
GR Supra, Retired: e46 m3, CRG Rotax Max
Is there a way to have 3 settings like:
normal
Sport 1
Sport 2
would like to have a normal mode for daily driving, sport 1 for sport mode but normal dampeners for bumpy roads then Sport 2 for sport dampeners for better roads…
BimmerGuy
Michael
Cary, NC, USA
MKV Supra m/t
normal
Sport 1
Sport 2
Unfortunately, no. You'll need to buy a real BMW ///M car to have multiple settings (along with cool little buttons on the steering wheel).
Or buy a Cadillac Blackwing which has multiple configurable modes.
BeepBoop321
Eric
I wonder what would happen if we retrofit a z4 g29 steering wheel and then add this module that toggles sports mode up/down, and code in sport+. This will give us the functionality that @MavJ requested: https://acmtechnik.com/products/f-series-steering-wheel-drive-mode-retrofit-kit
BackToBlack
2024 Supra 3.0 MT
normal
Sport 1
Sport 2
https://www.supramkv.com/threads/coded-sport-with-bimmercode.13328/
Code in the Sport+. Then when you press the mode button, you'll cycle through Normal, Sport Individual and Sport+ (your Sport 2 that has everything maxed out)
MavJ
J
YVR
jchadwell
Jerry
WV
2021 3.0 Premium
Thank you for this. Can sport 2 also be adjusted as I prefer normal steering over sport steering as normal steering has better feedback in my opinion!!
Yes. You can adjust everything in Sport Individual. I don’t have a need since I did not do the latest recall so my start/stop is still coded out with BimmerCode. Theoretically though you could use BimmerCode to start in Sport mode while having sport individual set to normal for everything. The only thing that’s unclear is whether it would apply Sport+ or Sport Individual settings if coded to start in Sport Mode.
