Broke clip for intake breather hose
J29DB03
Am I the only one who didn’t break it while changing the pipe?
i3igpete
Chicago
2023 3.0L 8AT
Don't get too cocky, I replaced mine successfully tiwce and then broke it reinstalling on the third time around
Tsuyim
Chueyee
Appleton
Supra
Any one got a link where I can buy a replacement clip? I broke mine trying to take it off ?
Axix23
GA
When installing the MST v2 intake pipe, I broke about half of the incredibly fragile clip that holds the breather hose into place into the bottom intake pipe. The tube still seats properly into the intake and appears to be mostly sealed. It also looks like it's a bitch to replace the entire hose.
Do I just need to bite the bullet, remove everything, and replace this hose?
Yes, it will be best to get a new one ☝
SilverMk5
Toronto
2021 Supra 3.0 - 2000 S2000 - 2013 Civic Si Cpe
Have to replace the whole hose. I got my local toyota dealer to order one in and install it for me. I ordered an extra one too because I know Im gonna break it when I go to install my chargepipe
No3jz
North Carolina
2024 Supra Premium 3.0. 1996 bmw 328. 2002 bmw 325
There's an orange O-ring in the turbo inlet pipe I transferred over that helps with the seal. This is assuming you got the V2 that replaces the full assembly all the way down to the turbo. Hopefully you can see it in both videos.
how do I know if I broke the breather hose? It seems looser than when I started but I don't see anything broken but its pretty hard to see on the engine side of things
shaloot
24 Supra 3.0p MT
Guys, do yourself a favor and make your own. This one has plenty of length for allowing easy removal with any intake.
-RJM
I bought a spare to do exactly this. Using a catch can will need something like this anyway.
After seeing the directions for the radium catch can install where they have you remove the plastic ends of this hose.
But I swear in their document it mentioned that one of the barbs takes 1/4 inch hose while another one takes 5/16ths. Indicating the barbs are 2 different sizes.
To my actual point of this post:
I see you used 1/4” hose, I assume it stays on just fine, did you notice if one of the barbs was larger?
Loco38SUP
One of the barbs is bigger, the flexible line stretched enough to fit fine. The spring clamps were just for extra security.
-RJM
