How to Improve OE Sub Bass Quality and Eliminate Vibrations
afkdoorbell
Reggie
The Lone Star
A90, TMY
Do not overpack the bass cavity with wading...You'll destroy lower bass response..
As described in my writeup only the inner walls of the cavity should be covered...I know some people have had problems in the past placing the thin sheet wadding against the walls...And although less than ideal, you can also pull the wadding sheets apart to fluff them up and very loosely fill the cavity...Just do not compress the wadding or you'll greatly reduce low end bass response...
Hi,
So the key is to fill the cavity with the wadding but not pack it to max?
I filled mine up but haven't filled to the point where I can't stuff any more.
I just didn't know how to know when is the right amount?
Mine isnt' the roll up type, it's the polyfill
https://amzn.to/45NwpBW
swrdply400mrelay
Hi,
Not sure how to quantify it, but I initially packed it tight and tested the bass, it was horrible. Took some out and improved a lot. I’d test the sound to see if you can tell there’s an improvement.
afkdoorbell
Reggie
The Lone Star
A90, TMY
Yeah I'll play with how much. From what I'm seeing and reading, maybe have enough room for air flow and room inside.
calmeda1
Christian
FL
2021 Toyota Supra 3.0 Premium
Hi,
I originally over filled it and it killed the bass. I took it all out and re-filled it just enough to cover the inner walls. 10000% better. Just cover the walls and leave the center hollow
afkdoorbell
Reggie
The Lone Star
A90, TMY
Yup, I took alot out and my god it sounds so good I wanna cry lol
My Supra actually sounds like it has subs instead of blown out 1920s speakers.
Yay!!
Loco38SUP
I did the same and took it all out. It sounded much better without it.
-RJM
tadda
tadda
Tom
Arizona
If you go back to my very first post the intent was never to fill the entire volume of the cavity with batting...The sheet batting was to be used to simply line all the metal walls to soften the internal reflections effectively increasing the cavity volume...
That said, some people seem to struggle with unfolding the sheet batting to line the cavity walls and it ended up that they started overstuffing / packing the entire cavity with the batting which to no surprise degraded the bass response!
Side note: Can't believe it's been over 5 years since my original post!
JerseyMKV3.0
Adrian
New Jersey
2022 Supra
Did this and added some EarthQuake SWS 2ohm since I have a Mobridge amp crazy different now appreciate this post!
chilly9797
Jeff
new Jersey
toyota Supra
Hey all! So I did the fix sounds better ported. Though I feel like I am now getting feedback from a rear tweeter. Doubt it has anything to do with it as the sub seems to be fine. Is it coincidence or anyone have this issue? Did I blow a tweeter on a 6 month old car?
mack73
'26 Final Edition
I did the normal mods here but was unhappy with the low hit - just not quite enough for me. So I swapped out my speakers with the Earthquake SWS 4ohm versions. Plug and play (includes spacer ring and wiring adapter to plug into OEM harness). Low hits are WAY better than the stockers - I haven't listened to the Bavsound or Alpha speakers so I can't compare, but for those that want some more low hit without an aftermarket amp/sub box this is a great option at $240 https://www.amazon.com/dp/B002MRD4SE . Thinking of adding some low pass inline filters to cut out the high frequencies. But even like it is now its great.
BMWAF
In orbit
A90 Supra; FN2 CTR
What was installation like. DId you just go in through the top?
JerseyMKV3.0
Adrian
New Jersey
2022 Supra
No, you have to prop up that subwoofer panel as the subs aren’t circular they have that proprietary shape. All in all not to bad of an install once you pull the other panels off.
JerseyMKV3.0
Adrian
New Jersey
2022 Supra
mack73
'26 Final Edition
As said above, you can't just go up through the carpet panel. I did it like in this video. Pulling all the plastic is the scariest part - and when you pull the panel with the 2 speakers below the seat belt, there are clips that go down behind the lower panel, not really explained in the video. You have to pull the top out and then up.
tuskenraider
Illinois
2026 Supra Premium MT
So after reading the majority of this thread, as well as watching a couple videos of people doing these modifications, I came across a comment that said the subwoofer are in a sealed plastic enclosure. Which then means as he noted, that adding ports does absolutely nothing to change the bass response. I could see the foam eliminating some vibrations, but that has to be minimal at best I would think. Has anyone put their hand at the ports and felt air movement when at a high enough volume to expect to feel something?
