DAW UltraFlow X Dyno results - 98 Pump gas
a90.faz
a90.faz
Faraz
Dubai
24’ 3.0 Premium | Matte Avalanche White Metallic
my car with DAW 6466
FTP charge pipe
CTS downpipe
MAD intake
everything else stock
on pump 98 and 15C temperature at night
boost 21 psi
i will get my dorch HPFP in a few days and we will up the boost
i will update
Nice! I was able to BARELY break 6. The goal for next year will be to break 5.
btw, your oil smoke problem is fixed?
No not yet. After installing the restrictor, I still am seeing smoke again. I have been logging and have lost about 5mm of oil level across 500km (full is 96mm raw oil level).
Shawn is going to send me an oil drain hose and smaller restrictor to try out in that order.
The issue was fixed for @Wazza after installing the drain hose. He is also a UFx user in the same country as me.
5mm in 300 miles? lol I don't even lose that after six track days.
a90.faz
a90.faz
Faraz
Dubai
yes, I see large puffs of smoke when I pull hard in higher gears ? Shawn thinks it’s the oil pump that is inconsistent between cars and in some cars sends too much oil to the turbo
Of course he does. He shifts blame for his smoky turbos to anything BUT his smoky turbos.
That excuse is total BS as it's PWM regulated.
dustwhyn
Dustyn
2024 M240i xDrive
Shawn will do anything and everything he can to not cover his products after they’ve been shipped. Same with Tony Vargas. If you want a hybrid, go with Pure. Otherwise go full frame.
_Sp1ral0ut
Jeff
SC
2021 Supra, 2026 Sequoia, Nike Air Max Torch 4s and flip flops
Maybe he just takes his turbos to the smoke shop with him. Did anyone ever stop to investigate that?
Jesse DaBears
Jesse
Illinois
IDK what happend with the DAWs they were great. After the UFR turbos came out a lot of customers started to complain about the oil smoking issue. Everyone I worked with i believe have had it resolved from new drains or an oil restrictors.
Pure had all these issues originally now with the new cast manifolds and turbos that dont require a core they seem to be doing really well without issues.
a90.faz
a90.faz
Faraz
Dubai
To be fair to Shawn, he is very responsive and has been helpful in troubleshooting. He replies very fast and is send these parts to try and fix it at no cost.
Some small issues are just the nature of the beast when modding. Nothing is perfect. I’m happy with the UFx, is performing great for my needs and haven’t had any major breaking issues.
sams2k
sam
israel
i have the DAW 6466 and talked with shawn a few times
he is very nice and answer super fast
in a simple google search about pure turbo i can also find very bad stories
so what?
a lot of my friends use pure turbo with great results
i3igpete
Chicago
2023 3.0L 8AT
The guy literally blames stock intakes for Turbo failures. has gone on the record about it.
a90.faz
a90.faz
Faraz
Dubai
Update on oil consumption: Shawn finally sent me the larger drain hose and smaller restrictor last week. I have now installed the drain and swapped my large restrictor to the smaller one. Logging oil level to see if issue is fixed ?
Extreme Power House
x-ph.com
18 BMW M4, 13 Mustang GT
:thumbsup:
Lil_Soopie
Houston, TX
2022 Supra Absolute Zero, 2003 IS300 Sportcross
I figured I would chime in here since I have a DAW6769 that has been on the car for roughly 6 months or so. I personally have not experienced any oil leak or consumption issues since it has been on the car. With that being said, I’ve had multiple people PM about the DAW and I always try to be objective with my response. While I have no encountered any problems, it is clear that has not been the case for others. I am happy with its performance, but that might change down the road haha Pure seems to have taken corrective action to address past issues and their latest product offering appears to be much improved. I plan to push the turbo to its limits and if it takes a shit, I will probably upgrade to top mount.
AJRMKV
2023 Manual Supra
Also, did some 100-200 draggy runs, here’s the best one. These are my first ever draggy runs, but I was told at my power level I should be able to get 6.8s 100-200. I will do some more runs soon with cooler weather at night.
Were you able to improve on this in lower temps? I’ve been doing some 94 octane pulls recently. The car dyno’d at 550whp on mainline hubs which is ~ 591whp SAE DJ at 24PSI.
MT trans remnant turbo. Ambient was definitely helping. Granny shift was .4 seconds
swrdply400mrelay
What’s the 100-200?
