how the cooling system works?
sams2k
sam
israel
hello
im trying to understand how the cooling system works
i read that there is 3 coolers for the intake(heat exchanger and 2 remote radiators), 1 radiator for engine coolant and 1 cooler for the transmission?
i try to look for videos that explain what the remote radiators do but could not find one, only short videos on how to install.
i just ordered the csf heat exchanger and trying to decide if i need the remote units too ?
and about the transmission cooler ? anyone using an aftermarket one ? any before and after logs ?
thank you very much
It's late and I'm tired, but the short version is no. You don't need to change any other heat exchangers to reap all of the benefits of an aftermarket intake manifold.
sams2k
sams2k
sam
israel
ok, so no, i will change only the big heat exchanger
but i didnt understand the rest of the comment about the intake manifold
please explain when you have time
Sorry- it was late and I was tired. I thought you ordered the intake manifold. :| Ignore most of what I said, you're good.
sams2k
sams2k
sam
israel
still trying to get more info on how the cooling system works
FuzzyRev
RT
Wisconsin
If you really want to know, I can post up some info tomorrow (leaving work in three minutes). Honestly, it's pretty complex from what I remember, but interesting nonetheless.
Jayson415PR
Jayson
Puerto Rico
2021 Toyota Supra 2003 Toyota Mr2
hello
thank you very much
Actually you got it wrong. There are 3 radiators for the engine, 1 is the heat exchanger and 1 for the transmission.
sams2k
sams2k
sam
israel
thanks for the great info
i will see and read everything
sams2k
sams2k
sam
israel
yes i want
when you can, please share
PaulFRDE
Paul
Germany (BW)
Red Supra 3.0 2022, Black BMW 116i 2022
You could try this link, or google "BMW B58 Information PDF" and the first couple results should have the surface level information on the cooling system you are interested in.
https://f30.bimmerpost.com/forums/attachment.php?attachmentid=1277450&d=1441950445
Thanks a bunch!
To sum up the initial question:
-The front center radiator uses coolant to cool the compressed air AND the A/C condenser
-The 2 from sides radiators uses coolant to cool the engine itself AND the transmission(page 38)
->I suppose both coolers are linked to both the engine and transmission?
-The LSD is only cooled by air?
FuzzyRev
RT
Wisconsin
Cheesedawg
East Coast
2022 Toyota GR Supra 3.0 Premium
This is the same information I was going to post, and my source isn't in nearly as pleasing of a format, so thanks!
I forget the post on these forums, but someone had linked it previously and it does make for some interesting reading on the designs and decisions when making the B58. Even if it is mostly intended as marketing wankery. Luckily it was easy to find.
