How to Improve OE Sub Bass Quality and Eliminate Vibrations
METAL
K2
Peoria, AZ
www.instagram.com
No longer have a need for my ported panel. Willing to swap (no cost) with anyone local to me. Peoria, AZ.
foywilliamd
Will
Houston
2021 Supra 3.0
MKV Owners:
Have any of you upgraded the factory JBL sound system in the 2020/2021 Supra?
After porting the factory box and adding acoustic foam and dynamat, I am still not pleased with the low range bass response.
Iā€™ve seen many mixed reviews about the performance of the Bavsound Ghost subwoofers. Some people love them, some people say they donā€™t sound much different.
I think it has a lot to do with the factory amplifier.
Considering replacing the amp (suggestions?) as well as the subwoofers with something like the Rockford Fosgate P3SD4-8, which is a shallow-mount subwoofer. Though, I donā€™t think it will fit into the OEM subwoofer box without modifications (it is still too deep). Iā€™d like to maintain an interior look as close to stock as possible, as trunk space is already limited, and this is my daily driver. This means an additional sub and box is out of the question.
Adding links to the modifications Iā€™ve made so far, as well as to the subwoofers mentioned above.
https://www.bavsound.com/products/ghost-subwoofer-upgrade-for-toyota-supra
https://www.crutchfield.com/p_575P3SD48/Rockford-Fosgate-P3SD4-8.html?cc=02&tp=111
https://www.supramkv.com/threads/how-to-improve-oe-sub-bass-quality-and-eliminate-vibrations.5092/
Thoughts?
89 and 95
Scott
Phoenix, AZ
2020 Supra, V8 Solstice Coupe, 21 C8, 88 V8 Fiero
Got my Supra back from inMobile/Soundwerks in Scottsdale after they played with various iterations of the above fixes for sub quality and overall stereo performance. I was not part of the day to day discussions, but just know all sounds fantastic now. Ended up with a DSP amp running new subs in the oem enclosure -- I guess the key to making it all work was a module that eliminates the oem amp completely. Anyone in the area, take your car to Don at inMobile and they can do the same.
foywilliamd
Will
Houston
2021 Supra 3.0
@89 and 95 can you provide links to the amp and subs you are running now? And maybe pictures of your interior? Thanks in advance!
89 and 95
Scott
Phoenix, AZ
Check with inMobile on specifics. Interior is oem (amp is hidden). Only visual difference is the gain dial for the sub, which is below steering wheel.
METAL
K2
Peoria, AZ
www.instagram.com
MKV Owners:
Thoughts?
Whats your budget?
METAL
K2
Peoria, AZ
www.instagram.com
foywilliamd
Will
Houston
2021 Supra 3.0
Update for all - I think the Rockford Fosgate P3SD4-8 Shallow Mount 8ā€ subwoofers
Whats your budget?
Budget is ideally $1500 or less. I think Iā€™m going to proceed with the two RF subs mentioned before with a 500W amp. Iā€™ll keep the forum posted on results either way.
METAL
K2
Peoria, AZ
www.instagram.com
What do you plan to run those subs at Frequency wise? Keep in mind the oem subs are playing mid bass and sub bass.
foywilliamd
Will
Houston
2021 Supra 3.0
Honestly Iā€™m not sure. There are some highly rated audio shops in town, I was planning to have them do the majority of the work. Do you have recommendations?
METAL
K2
Peoria, AZ
www.instagram.com
The concern here is by deleting the oem subs you are removing a chunk of the frequency band that the cabin speakers do not play. Asking an aftermarket sub to replace those frequencies is a tall ask and will not sound good. Best option is to leave those oem subs alone and add a sub in the trunk.
nosavingthrow
Seattle, WA
For the speaker wadding, cut with the template: which side goes up/down? Like it gets folded into a box shape, do you leave the top open, or bottom open once you get it into the enclosure?
tadda
tadda
Tom
Arizona
fold such that top is open....
spta97
2021 Supra, 2020 BMW X3MC
Doh! Me and g/f did this mod today and put the wadding in the wrong way! :nono:
It didn't make sense to me as I figured the port from the sub would be blocked but guess I read the directions wrong.
I wish I had read this post or further back as I just now read through every page.
We'll fix tomorrow, but in the mean time it made a huge improvement!
Wanted to say thanks Tadda! Awesome job and awesome write up!
